Problem in RF Management AP Mode
  • 1.  Problem in RF Management AP Mode
    Posted Mar 09, 2017 01:54 AM
    Hi Everyone,
    The issue is in RF Management, the Access Point is already in AP mode. However, looking at monitoring, it shows that the AP is still in monitor mode. The model of AP is Apin0325 while for the controller it is 7210. The firmware version of the controller is 6.5.0.4.
    Hoping that you guys can help. It will be greatly appreciated.
  • 2.  RE: Problem in RF Management AP Mode
    Posted Mar 09, 2017 03:09 AM
    On the commandline, "show ap active" should tell you the mode of the radio accurately.
  • 3.  RE: Problem in RF Management AP Mode
    Posted Mar 09, 2017 03:20 AM
    Thanks Colin.
  • 4.  RE: Problem in RF Management AP Mode
    Posted Mar 09, 2017 06:26 AM
    Hi Guys,
    Additional information. 11a and 11g are in AM. What is the command to set 11g ch/eirp/maxeirp to AP?
  • 5.  RE: Problem in RF Management AP Mode
    Posted Mar 09, 2017 08:57 AM
    First, what country code is this controller set to (or what country are you in)? You may need to download a new DRT file from support to get the latest regulatory information for your AP (assuming it's not configuration related). If you put the 325 into the same group as any of your other APs that are running fine, and if the radios don't come up, 99/100 it's regulatory and you likely need to upgrade code or just upgrade the DRT file to allow the 325 to run.
  • 6.  RE: Problem in RF Management AP Mode
    Posted Mar 09, 2017 09:06 PM
    Hi Sir Jerrod,
    Is there a way to configure the country code of Aruba ap-325? The unit seems no GUI so maybe theres a way in configuring the country code in CLI. Thanks.
  • 7.  RE: Problem in RF Management AP Mode
    Posted Mar 09, 2017 09:57 PM
    What country code and controller type (US, RW, IL, JP, etc) is it?
