Problem Mac Filtering Aruba controller 7205
  • 1.  Problem Mac Filtering Aruba controller 7205
    Posted Jan 28, 2018 03:37 PM
    Thanks in advice for your help.
    I already configure all the stuff for this to work, but I’m missing something, for example is necessary the PEF license for this to work.
    I just need that a SSID work with PSK+Mac Filtering.
    Thanks a lot.
  • 2.  RE: Problem Mac Filtering Aruba controller 7205
    Posted Jan 28, 2018 03:41 PM
    Yes.
    You need the PEF license to have a different role after mac authentication.
  • 3.  RE: Problem Mac Filtering Aruba controller 7205
    Posted Jan 28, 2018 03:52 PM
    Thanks a lot for your quick answer, I know is a stupid question, it’s possible to activate that license in some way as demo or is necessary to buy it.
    Or if you know a workaround to solve the issue without buying the license.
    Sorry for my English.
    Again thank you very much
  • 4.  RE: Problem Mac Filtering Aruba controller 7205
    Posted Jan 28, 2018 04:46 PM
    If I implement clearpass I will need that license too?
  • 5.  RE: Problem Mac Filtering Aruba controller 7205
  • 6.  RE: Problem Mac Filtering Aruba controller 7205
    Posted Jan 28, 2018 05:53 PM
    It seems that I am wrong.  Check to see if you can execute these commands:
    config t
    aaa authentication mac mac-profile
     Not having the PEF license could significantly reduce your productivity, however.  You would be limited even if you add ClearPass..
