Problem Master-Local Controller
  • 1.  Problem Master-Local Controller
    Posted Feb 05, 2012 11:29 PM
    We have problem with master controller and local controller, master and local cannot synchronize. Master Controller Aruba OS Version 3.4.4.3 and Local Controller Aruba OS Version 6.1.1.0.
    We ask for the best solution,what should we do.
  • 2.  RE: Problem Master-Local Controller
    Posted Feb 05, 2012 11:52 PM
    this eror log master and local controller http://www.mediafire.com/?ge8oto8l2lgmqle
  • 3.  RE: Problem Master-Local Controller
    Posted Feb 06, 2012 03:39 AM
    can i downgrade  Aruba OS 6.1.1.0 to Aruba OS 3.4.4.3 ?
  • 4.  RE: Problem Master-Local Controller
    Posted Feb 06, 2012 04:32 AM
    They cannot synchronize because they are different major versions of code.
    You can try to downgrade, if the second controller is not terminating live APs, but I cannot promise it will work.
  • 5.  RE: Problem Master-Local Controller
    Posted Feb 07, 2012 02:11 AM
    You should be able to downgrade, but I would upgrade the master controller instead.
  • 6.  RE: Problem Master-Local Controller
    Posted Feb 07, 2012 02:25 AM
    We have Aruba 650 series,we downgrade Aruba OS 6.1.1.0 to Aruba OS 3.4.4.3, we have problem with Policy Enforcement Firewall Next Gen License (16 AP Support), error message Key contains limits that are not valid for ArubaOS. We want activation key working for Aruba OS 3.4.4.3. What should we do,we hope for best solution.
  • 7.  RE: Problem Master-Local Controller
    Posted Feb 07, 2012 06:17 AM
    You should contact support, to geet a temporary license.
