Problem updating firmware after upgrading to 8.2.15.0
  • 1.  Problem updating firmware after upgrading to 8.2.15.0
    Posted Oct 29, 2022 09:49 AM
    I updated my Airwave sever to version 8.2.15.0 yesterday and since then I've been having problems upgrading the firmware of my accesspoints.
    To begin with I couldnt even schedule any upgrade jobs, I was just met with an error message each time.
    I then contacted the Aruba support who informed me that there was a bug related to firmware upgrade in this version and they then proceeded to applied a patch that was supposed to resolve the problem.
    While it did make it possible for my to schedule the upgrade jobs again when I do the jobs don't contain any devices.
    I just figured I'd throw out the question here if anyone experienced anything similar ?
  • 2.  RE: Problem updating firmware after upgrading to 8.2.15.0
    MVP GURU
    Posted Oct 31, 2022 07:17 AM
    Can not say I have seen this. Are you continuing to work with TAC to see what else may have come up as a bug?
    Dustin Burns
    ACCX 1271| ACMX 509| ACSP | ACDA | MVP Guru 2022
