Problem with a IAP 315 RW - With POE lights off, with external DC power red ligth blink
  • 1.  Problem with a IAP 315 RW - With POE lights off, with external DC power red ligth blink
    Posted Jul 10, 2017 05:51 AM
    Hello to all,
    I have a problem. The IAP 315 Wifi don't boot. If I connect with ethernet POE lights are off (in the same wire i can to connect another iap 315 and works fine) if I connect external power DC adapter (original) a red led blink on device.
    I cant to access for admin it.
    There are a mode for recovery or i need open a RMA?
    Thanks a lot,
    Enrique.
  • 2.  RE: Problem with a IAP 315 RW - With POE lights off, with external DC power red ligth blink
    MVP EXPERT
    Posted Jul 10, 2017 06:00 AM
    Hey, if this is the POWER LED then there is a system error and you will need to speak to TAC. Do you see any console output when you attach a console cable?315-system-led.jpg
  • 3.  RE: Problem with a IAP 315 RW - With POE lights off, with external DC power red ligth blink
    Posted Jul 10, 2017 06:21 AM
    I connected the DC adapter and ethernet Poe and now is running, but i dont know why.
    I will continued testing.
    Enrique.
  • 4.  RE: Problem with a IAP 315 RW - With POE lights off, with external DC power red ligth blink
    Posted Jul 10, 2017 06:52 AM
    What model POE adapter are you using?  Does that POE adapter work with anything else?
    It should work with and 802.3af or 802.3at poe source, according to the datasheet here:  http://www.arubanetworks.com/assets/ds/DS_AP310Series.pdf  Any other POE standard will probably not work.
    If you plug in the power adapter, it will override the POE injector.
