I am having the same problem, the configuration remains in the "verifying state", and i beleive that it doesn't let me configure my IAP cluster.
Has anyone found an answer to this problem yet? I'm working with the 8.2.5.1 version of airwave
Is there anything in the igc.log detailing what audit actions are being performed? Is there a support case for this? I can try to escalate if there's a case opened.
looks like I´m having the same issue... how can we troubleshoot this it`s really frustrating when you don`t see anything what`s happening on the system itself...
The IGC process logs to /var/log/igc/igc.log. You can see this log from System -> Status -> IGC. If you're using templates instead of IGC, then try looking into the audit log or the config verifier log. Beyond that, opening a support case would be the next step.
