Hi all
i have set up a network on iap 205s and set the access rules to allow internet only,
the issue im having is that people with an email account that sincs with there apple device cannot get the emails. i guess i just need to add an access rule or 2 but could do with some advice.
many thanks
Check what ports the app uses and allow that traffic on your post authentication role.
You will have to check to see what ports your users need. A quick check in google shows me that some sync over 80 and 443 - which should work, but others use IMAP or SMTP or some other oddball ports.
Is there a reason you only allow 80 and 443?
