problem with ArubaInstant_Scorpio_8.6.0.6_77124
  • 1.  problem with ArubaInstant_Scorpio_8.6.0.6_77124
    Posted Dec 28, 2020 04:08 PM
    Hi
    I have working a cluster with differents models of Aps.
    the master is a AP-555, and others, 4 units of AP-515,  6 units of IAP-225, 2 units IAP-275.
    The system is running with  ArubaInstant__8.6.0.6_77124, and I´m having problems , CPU too busy, conflicts with the switch, traffic blockeds, etc.
    I have read that version 8.6.0.7_78215, solve these issues, I can not go to 8.7 versions because IAP-225 and IAP 275are not compatible.
    I´m trying to download 8.6.0.7_78215, but I can´t do it
    anybody knows how download this version, I need DRACO,CENTAURUS and SCORPIO.
    thank you for your support
    javier manzanares
  • 2.  RE: problem with ArubaInstant_Scorpio_8.6.0.6_77124
    Posted Dec 29, 2020 04:25 AM
    Javier,
    I have just verified that all three images are available and downloadable. Try this search:
    https://asp.arubanetworks.com/downloads;search=8.6.0.7;products=Aruba%20Access%20Points
    If you are still encountering difficulties with the download,  contact our support directly:
    https://www.arubanetworks.com/support-services/contact-support
    Best Regards
    Shawn
    Shawn Adams
  • 3.  RE: problem with ArubaInstant_Scorpio_8.6.0.6_77124
    Posted Dec 29, 2020 06:00 AM
    Hi Shawn.
    Today, I haven´t had any problem, everything is working fine, I can download.
    Thank´s
  • 4.  RE: problem with ArubaInstant_Scorpio_8.6.0.6_77124
    MVP
    Posted Dec 29, 2020 07:27 AM
    Why not use the conservative 8.5.x release? I see it supports the 550 series APs.
    Bruce Osborne
