Problem with bulk guest account creation in AOS8.5
  • 1.  Problem with bulk guest account creation in AOS8.5
    Posted Sep 06, 2019 03:50 AM
    we upgraded our MobilityMaster, Controllers an d APs from 8.4.0.1 to 8.5.0.2 . We noticed that after the upgrade the csv bulk upload at our MobilityMaster (MM) internal authetication guest user page is not working anymore.
    When i upload a .csv the page 'stalls' and nothing happens, after i press cancel, the import window closes and the first few (1-3) accounts are created. All other accounts are discarded and i did not recieve the usual confimation file download.
    When i revert the MM to 8.4.0.1 the import works correctly. After an update to 8.4.0.4 it still works good.
    Does anyone else have the same problem with 8.5.x.x? If yes, how can i file a bug report?
    Greetings
    Markus
