problem with ClearPass Guest - login page just reloads
  • 1.  problem with ClearPass Guest - login page just reloads
    Posted Aug 28, 2017 08:53 AM
    Hi
    I have a problem with ClearPass Guest
    I am able to get to the Clearpass Guest Login page
    However once I click login the page just reloads (with no error messages)
    No messages show up in access tracker
    I also do not see Radius request using wireshark
    However if I leave pre-auth checked on the web login page
    I do see the accounts details appear in access tracker
    but with authentication failure 204
    It seems that there is no Radius Request been submitted after clicking login
    I did also test using an "employee" SSID with ClearPass connected
    to AD and that works 100%
    some details on setup:
    network
    Flat layer 2
    IAP using VC virtual IP: 192.168.100.214
    ClearPass IP: 192.168.100.211
    Controller:
    IAP 205 VC - Version: 6.5.0.0-4.3.0.2_57688
    default certificate
    securelogin.arubanetworks.com
    setup as per setup Guide and videos
    I have checked
    Captive portal profile -
    hostname URL
    I have tried with pre and post auth roles and unrestricted
    ClearPass
    default certifcates for Radius and HTTP
    Tried multiple services (but cant see how that can be the issue
    as I am not seeing anything in access tracker)
    Configured IAP VC as the NAS device
    Under Guest setup:
    created Guest account
    created Web login page left everything as default
    used securelogin.arubanetworks.com as the address which resolves to 192.168.100.214
    I do have internet breakout
    any other ideas please?
    thank you
  • 2.  RE: problem with ClearPass Guest - login page just reloads
    Posted Aug 28, 2017 08:55 AM
    You need a public CA-signed certificate for captive portal.
    Which device type are you seeing this behavior on?
  • 3.  RE: problem with ClearPass Guest - login page just reloads
    Posted Aug 29, 2017 10:03 AM
    Hi Tim
    I see this on my Android phone and using Firefox on my laptop
    On FireFox the usual "This connection is unstrusted" message appears
    I add the exception and click on "I understand the risk"
    I then comes up with the following message:
    "To display this pageFirefox must send information that will repeat any action (such as a search or order confirmation) that was performed earlier"
    I have to click on resend, it then just reloads the login page with no further error messages
    thanks again
  • 4.  RE: problem with ClearPass Guest - login page just reloads
    Posted Aug 29, 2017 10:07 AM
    You need to add a public CA-signed captive portal certificate to your VC.
  • 5.  RE: problem with ClearPass Guest - login page just reloads
    Posted Aug 30, 2017 03:00 AM
    Hi Tim
    thank you will give  that a go and feedback
    thanks again
