SD-WAN
problem with controller connection
  • 1.  problem with controller connection
    Posted Dec 04, 2015 08:37 AM
    Hi all
    Problem: can*t connect to the remote controller!
    to do: I try to create the simple topology with 3 VLANs. first - normal switch routing. second - OpenFlow + VoIP. third - controller. My switch 2920-24G. Firmware - 15.14.0012. How can I make conections beetween vlans and what about ip`s? Should I use gateways? It`s my first switch =)
    HP-2920-24G(config)# show running-config
    Running configuration:
    ; J9726A Configuration Editor; Created on release #WB.15.14.0012
    ; Ver #06:0c.18.f3.ff.35.0d:26
    hostname "HP-2920-24G"
    module 1 type j9726a
    snmp-server community "public" unrestricted
    openflow
    controller-id 1 ip 10.22.1.12 port 6653 controller-interface vlan 3
    instance "test"
    listen-port 6653
    member vlan 2
    controller-id 1
    version 1.3
    enable
    exit
    enable
    exit
    oobm
    ip address dhcp-bootp
    exit
    vlan 1
    name "DEFAULT_VLAN"
    no untagged 17-24
    untagged 1-16,A1-A2,B1-B2
    exit
    vlan 2
    name "hosts"
    untagged 17-23
    no ip address
    voice
    exit
    vlan 3
    name "VLAN3"
    untagged 24
    no ip address
    exit
    HP-2920-24G(config)# show openflow instance test
    Configured OF Version : 1.3
    Negotiated OF Version : NA
    Instance Name : test
    Admin. Status : Enabled
    Member List : VLAN 2
    Listen Port : 6653
    Oper. Status : Up
    Oper. Status Reason : NA
    Datapath ID : 0002480fcf0a8680
    Mode : Active
    Flow Location : Hardware and Software
    No. of Hw Flows : 0
    No. of Sw Flows : 0
    Hw. Rate Limit : 0 kbps
    Sw. Rate Limit : 100 pps
    Conn. Interrupt Mode : Fail-Secure
    Maximum Backoff Interval : 60 seconds
    Probe Interval : 10 seconds
    Hw. Table Miss Count : NA
    No. of Sw Flow Tables : 1
    Egress Only Ports : None
    Table Model : NA
    Controller Id Connection Status Connection State Secure Role
    1 Disconnected Connecting No Equal
    Can anybody detect my problem, or give advise what to do?
    Thank you for atention.
    #vlans
    #floodlight
    #Controller
    #Port
