Problem with converting a IAP-365 to a RAP
  • 1.  Problem with converting a IAP-365 to a RAP
    Posted Feb 28, 2018 02:52 PM
    Dear Community,
    I have a really strange problem. At a customers site is a IAP-365 installed which shall be converted to a RAP. Other IAPs of different types (IAP-207 and IAP-103) converted without any problems.
    When I start conversion via "maintenance >> convert" menu I'll get a nonsense error message. (attached screenshot)
    What I've already checked:
    The AP can ping the desired controller address which includes a correct routing and successful DNS resolution. Also any other destinations (i.e. device.arubanetworks.com, google.de, etc.) are reachable.
    There are no firewall rules in place which might prevent communication.
    I did an upgrade to latest 6.5.4.5 and - after no change in behavior - a downgrade to 6.5.4.0.
    I did also an "swarm-mode Standalone" to prevent joining this IAP to another IAP-VC in the same network.
    When I observe the traffic at the customers firewall I see all the DNS- and ICMP- packets but NOT any UDP/4500 packets which should be seen during the VPN setup.
    Also when I start the conversion at the CLI via "convert-aos-ap ..." absolutly nothing happens.
    I also tried to initiate the convert via Aruba Activate but the IAP has no cloud activation key. A "show activate" shows serial, MAC and all the other information but no cloud key.
    Any help is highly appreciated!
    Timo
  • 2.  RE: Problem with converting a IAP-365 to a RAP
    Posted Mar 05, 2018 03:59 PM
    Can you share the controller image version and following log from IAP after conversion has failed:
    show log convert
    Also if you default the IAP-365, it will have the unified code controller discovery process and should find the controller that way!
  • 3.  RE: Problem with converting a IAP-365 to a RAP
    Posted Mar 10, 2018 02:43 PM
    I'm having the Same issue with IAP205.
    Testing it on MM and MC architecture AOS8.2.
    Any insight will be much appreciated.
  • 4.  RE: Problem with converting a IAP-365 to a RAP
    MVP EXPERT
    Posted Mar 11, 2018 05:49 AM
    @a_harkati are these Virtual Appliances?
  • 5.  RE: Problem with converting a IAP-365 to a RAP
    Posted Mar 11, 2018 01:04 PM
    After a lot of troubelshooting together with remote support by HPE we figured out, that the problem was caused by a defective TPM on the IAP itself. In fact the IAP couldn't authenticate against the Activate Portal (device.arubanetworks.com) nor as a RAP against the mobility controller.
    Finally the IAP-365 will be replaced as an RMA.
    Try to check output of "show ap debug | inc awc" and "show log provision".
    Timo
