Problem with DHCP local scopes
  • 1.  Problem with DHCP local scopes
    Posted Dec 03, 2018 02:59 PM
    Hello all, I am new to using aruba AP and I have a problem while configuring local DHCP scopes.
    The currrent configuration I have is 5 305 AP (1 master and 4 slaves) and I want to have 4 different SSIDs, 1 of these is spreading on all APs, the other 3 however are just spreading on different APs, let's say SSID 2 on AP 2, SSID 3 on AP 3 and SSID 4 on AP 4, so far so good.
    Then I assign different pools to the SSIDs, the network spreading on all AP is 192.168.1.0/24 and it's configured as a guest network, network on SSID 2 is 192.168.2.0/25 with a local DHCP scope assigned to VLAN 2, network on SSID 3 is 192.168.2.128/25 with a local DHCP scope assigned to VLAN 1, up until this point is running as intended and I have no problems with it.
    Now, the problem comes when I try to assign network 192.168.3.0/25 with VLAN 3 as a local DHCP scope to SSID 4, for some reason when I do this and connect to the AP it gives me a 192.168.2.X IP address and I cannot figure out why.
    It's worth mentioning that this only happens when I spread this network on slave AP, if I put the network to spread on the master it works perfectly.
    Please help, and thanks for the answers!
    P.S.: If you don't understand something or my question is not clear, please let me know and I'll try to rephrase it since english is not my first language
  • 2.  RE: Problem with DHCP local scopes
    MVP EXPERT
    Posted Dec 04, 2018 04:20 AM
    Any chance you can share a diagram, will be easier to understand. What is providing DHCP for the VLANs in question, the IAP or an external DHCP server.
  • 3.  RE: Problem with DHCP local scopes
    Posted Dec 04, 2018 12:46 PM
    The DHCP is provided by the IAP as "local DHCP scopes"
