Problem with getting IP on the CTRL+ALT+DELETE screen
  • 1.  Problem with getting IP on the CTRL+ALT+DELETE screen
    Posted Jan 11, 2017 07:36 AM
    Hi everyone,
    I'm working in a municipality with the wireless network. For some weeks ago we have started having some issues with computers not being able to retreive an IP-address from our DHCP-server at the CTRL+ALT+DELETE screen.
    We are using machine authentication with Clearpass and the client is accepted but the user is not able to login since the computer does not have an IP-address. If we login with a local user on the computer we can see that the wifi is connected but it has the yellow triangle above the wifi icon.
    I have searched but not found any solution to this. Only thing I can find is that some logs differ in the clearpass logs, see attachments. Can't find any other issues with the keywords I'm searching on. It affects both our new environment and our old.
    From logs:
    2017-01-11 11:56:59,007	[RequestHandler-1-0x7f7acfbdd700 h=92935534 c=R004e36d8-01-58760f7a] WARN Core.SessionInfoOperations - Skip SessionInfoOperations::persistSessionInfo because of NULL NAD or NAD IP matching localhost
    2017-01-11 11:56:59,007	[RequestHandler-1-0x7f7acfbdd700 h=92935534 c=R004e36d8-01-58760f7a] ERROR Common.NadClientTable - getNadClient: Unknown NadClient X.X.X.X
    2017-01-11 11:56:59,008	[RequestHandler-1-0x7f7acfbdd700 r=R004e36d8-01-58760f7a h=92935535 c=R004e36d8-01-58760f7a] INFO Core.PETaskRadiusCoAEnfProfileBuilder - getApplicableProfiles: No radius_coa enforcement profiles applicable for this device
    2017-01-11 11:56:59,012	[RequestHandler-1-0x7f7acfbdd700 h=92935541 c=R004e36d8-01-58760f7a] INFO Core.XpipPolicyResHandler - populateResponseTlv: PETaskPostureOutput does not exist. Skip sending posture VAFs
    2017-01-11 11:56:59,012	[RequestHandler-1-0x7f7acfbdd700 h=92935541 c=R004e36d8-01-58760f7a] INFO Core.PolicyResCollector - getSohr: Failed to generate Sohr
    2017-01-11 11:56:59,012	[RequestHandler-1-0x7f7acfbdd700 h=92935540 c=R004e36d8-01-58760f7a] INFO Core.PolicyResCollector - getSohr: Failed to generate Sohr
    New environment
    Controller: 7210
    ArubaOS: 6.5.0.2
    AP: Every model
    Old environment
    Controller: 3200
    ArubaOS: 6.3.1.9
    AP: Every model
    Computers are HP and running Win7 and Win10. Random computers with random models are affected and doesn't mather if it is Win7 or Win10. Can't find anything interesting in the event viewer.
    DHCP server is Windows 2012 R2. No logs of the computers exists when this problem occurs.
    Only solution is to restart the computer a couple of times and then it works but as you can understand it is not a very good solution. Not sure this is an Aruba problem or if it is HP or Windows but hopefully you can help me.
    Attachment(s)
    txt
    not_working.txt   19 KB 1 version
    txt
    working.txt   18 KB 1 version
  • 2.  RE: Problem with getting IP on the CTRL+ALT+DELETE screen
    Posted Jan 11, 2017 07:44 AM
    What role does the client have on the controller after Machine Authentication?
  • 3.  RE: Problem with getting IP on the CTRL+ALT+DELETE screen
    Posted Jan 11, 2017 07:51 AM
    It gets the role AD-Personal-Dator, [Machine Authenticated]
    This is the name it forwards to the controller and based on this it gets a network. Is it possible that the controller does not receive this?
    As I said in the first post, it is not all computers that are having problems.
  • 4.  RE: Problem with getting IP on the CTRL+ALT+DELETE screen
    Posted Jan 11, 2017 07:57 AM
    Did you verify the user-table on the controller? TIPS role in ClearPass !=
    role on the controller.
  • 5.  RE: Problem with getting IP on the CTRL+ALT+DELETE screen
  • 6.  RE: Problem with getting IP on the CTRL+ALT+DELETE screen
    Posted Jan 11, 2017 08:13 AM
    I have checked with a computer now and everything looks ok in Clearpass but the computer is not visible in the controller.
    Hmm, why is the controller not receiving the information?
  • 7.  RE: Problem with getting IP on the CTRL+ALT+DELETE screen
    Posted Jan 11, 2017 09:10 AM
    The computer is visible and connected to the AP when issuing "show user mac".
    It is not visible if I check "show user ap-name".
    Attachment is of debug log of the controller when the computer connects. Seems that it understands correct role but still no IP-address.
    (arubamaster) #show user mac f0:d5:bf:b7:c5:55
    The phy column shows client's operational capabilities for current association
    Flags: A: Active, B: Band Steerable, H: Hotspot(802.11u) client, K: 802.11K client, M: Mu beam formee, R: 802.11R client, W: WMM client, w: 802.11w client V: 802.11v BSS trans capable
    PHY Details: HT   : High throughput;      20: 20MHz;  40: 40MHz; t: turbo-rates (256-QAM)
                 VHT  : Very High throughput; 80: 80MHz; 160: 160MHz; 80p80: 80MHz + 80MHz
                 <n>ss: <n> spatial streams
    Association Table
    Name            bssid              mac                auth  assoc  aid  l-int  essid           vlan-id  tunnel-id  phy              assoc. time  num assoc  Flags  Band steer moves (T/S)
    AP1  18:64:72:f0:5d:51  f0:d5:bf:b7:c5:55  y     y      2    250    Municipality-SSID  85       0x1019e    a-VHT-80sgi-2ss  3m:11s       1          WAB    4/4
    f0:d5:bf:b7:c5:55-18:64:72:f0:5d:51 Stats
    Parameter                            Value
    Channel                              116
    Channel Frame Retry Rate(%)          8
    Channel Frame Low Speed Rate(%)      0
    Channel Frame Non Unicast Rate(%)    0
    Channel Frame Fragmentation Rate(%)  0
    Channel Frame Error Rate(%)          0
    Channel Bandwidth Rate(kbps)         2116
    Channel Noise                        97
    Client Frame Retry Rate(%)           0
    Client Frame Low Speed Rate(%)       0
    Client Frame Non Unicast Rate(%)     0
    Client Frame Fragmentation Rate(%)   0
    Client Frame Receive Error Rate(%)   0
    Client Bandwidth Rate(kbps)          0
    Client Tx Packets                    1697
    Client Rx Packets                    54
    Client Tx Bytes                      130039
    Client Rx Bytes                      16247
    Client SNR                           37
    A2c_SM SeqNum, Old SeqNums           18759 0
    (arubamaster) #show user ap-name AP1
    Users
        IP              MAC            Name                                 Role                 Age(d:h:m)  Auth    VPN link  AP name         Roaming   Essid/Bssid/Phy                         Profile           Forward mode  Type     Host Name
    172.21.28.139  ac:7b:a1:a2:b3:09  host/COMPUTER321.municipality.intra  AD-Personal-Dator    02:06:44    802.1x            Municipality-SSID  Wireless  Municipality-Kommun/18:64:72:f0:5d:51/a-HT   Municipality-Personal  tunnel        Win 7    ALM-ADM-KLF0004
    172.21.31.146  6c:fa:a7:13:44:2b                                        Municipality-PSK          24:00:41                      Municipality-SSID  Wireless  ah-adm/18:64:72:f0:5d:40/g-HT           Municipality-PSK       tunnel        Android
    172.21.27.146  34:12:98:cf:81:9d                                        Municipality-PSK          00:00:20                      Municipality-SSID  Wireless  ah-adm/18:64:72:f0:5d:50/a-VHT          Municipality-PSK       tunnel
    172.21.29.34   c4:b3:01:59:dc:d2                                        Municipality-PSK          00:00:24                      Municipality-SSID  Wireless  ah-adm/18:64:72:f0:5d:50/a-HT           Municipality-PSK       tunnel        iPhone
    172.21.27.51   d0:25:98:6e:95:d5  almpersipad                           ALM-PERS-IPAD        00:02:42    802.1x            Municipality-SSID  Wireless  Municipality-Kommun/18:64:72:f0:5d:51/a-VHT  Municipality-Personal  tunnel        iPhone
    172.22.21.7    f4:f9:51:be:72:73  f4f951be7273                          Guest-Device-ADMMOB  24:00:57    MAC               Municipality-SSID  Wireless  Municipality-Guest/18:64:72:f0:5d:52/a-HT    Municipality-Guest     tunnel        AppleTV  festlund-4
    172.23.0.18    b8:8a:60:87:6d:15  host/COMPUTER322.municipality.intra  AD-IT-Enheten        00:03:31    802.1x            Municipality-SSID  Wireless  Municipality-Kommun/18:64:72:f0:5d:51/a-VHT  Municipality-Personal  tunnel        Win 10
    172.22.17.7    44:2c:05:01:70:5e  442c0501705e                          Guest-Device-ADMMOB  08:06:23    MAC               Municipality-SSID  Wireless  Municipality-Guest/18:64:72:f0:5d:52/a-HT    Municipality-Guest     tunnel        Linux
    172.21.26.17   c8:1e:e7:ba:89:7c                                        Municipality-PSK          00:08:04                      Municipality-SSID  Wireless  ah-adm/18:64:72:f0:5d:50/a-VHT          Municipality-PSK       tunnel        iPhone
    User Entries: 9/9
     Curr/**bleep** Alloc:1423/688197 Free:279/686774 Dyn:1702 AllocErr:0 FreeErr:0
    Attachment(s)
    txt
    controller_debug_log.txt   11 KB 1 version
  • 8.  RE: Problem with getting IP on the CTRL+ALT+DELETE screen
    Posted Jan 11, 2017 09:21 AM
    Hi
    Had a similar issue, if you have ticked the "Enforce DHCP" in the AAA profile, there was a bug in the system, falsely stopping users from getting an IP address for whatever reason.
    This bug is fixed, i'm just not sure what patch on the 6.5 that is.
    By looking up the host in the controller Dashboard, you can see that client and it's role, even if you can't see it under Monitoring->Clients.
    This should at least clear up if it has the correct role or not.
    The log you included also states that the role is changed at some point, giving it the one you mentioned.
    Roar Fossen
  • 9.  RE: Problem with getting IP on the CTRL+ALT+DELETE screen
    Posted Jan 12, 2017 03:42 AM
    Thanks for your reply. I have checked my AAA configuration but I'm not using "Enforce DHCP".
    I have started a wireshark capture on a computer and it is sending ARP requests to the gateway in the network it is given but the gateway is not responding. Could the controller block the ARP traffic? Network is a /24.
    Broadcast             ARP           Who has 172.21.29.1? Tell 169.254.172.141
    I have also noticed that the mDNS process is taking 100% CPU in the controller. Could this be the issue?
     PID USER      PR  NI  VIRT  RES  SHR S %CPU %MEM    TIME+  COMMAND
     4712 root      20   0  144m  49m 9920 R  100  1.0  59903:08 mdns
  • 10.  RE: Problem with getting IP on the CTRL+ALT+DELETE screen
    Posted Jan 12, 2017 04:15 AM
    What role does the device have in the user table?  Type "show rights (role)"
  • 11.  RE: Problem with getting IP on the CTRL+ALT+DELETE screen
    Posted Jan 12, 2017 05:08 AM
    As I said before, it is not every computer in this role that has this problem.
    show rights AD-Personal-Dator
    Valid = 'Yes'
    CleanedUp = 'No'
    Derived Role = 'AD-Personal-Dator'
     Up BW:No Limit   Down BW:No Limit
     L2TP Pool = default-l2tp-pool
     PPTP Pool = default-pptp-pool
     Number of users referencing it = 496
     Periodic reauthentication: Disabled
     DPI Classification: Enabled
     Youtube education: Disabled
     Web Content Classification: Enabled
     IP-Classification Enforcement: Enabled
     ACL Number = 92/0
     Max Sessions = 65535
     Check CP Profile for Accounting = TRUE
    Application Exception List
    Name  Type
    Application BW-Contract List
    Name  Type  BW Contract  Id  Direction
    access-list List
    Position  Name                          Type     Location
    1         global-sacl                   session
    2         apprf-AD-Personal-Dator-sacl  session
    3         allowall                      session
    global-sacl
    Priority  Source  Destination  Service  Application  Action  TimeRange  Log  Expired  Queue  TOS  8021P  Blacklist  Mirror  DisScan  ClassifyMedia  IPv4/6  Contract
    allowall
    1         any     any          any                   permit                           Low                                                           4
    2         any     any          any-v6                permit                           Low                                                           6
    Expired Policies (due to time constraints) = 0
  • 12.  RE: Problem with getting IP on the CTRL+ALT+DELETE screen
    Posted Jan 12, 2017 05:20 AM
    I would type "show audit-trail" on the controller to see if there were any changes made in the timeframe when problems started happening; or you can open a TAC case.  There are simply too many reasons why this would happen and a TAC case would be the best way to obtain your tech-support and narrow down the issue.
