Problem with IP Class 192.168.10.x and 192.168.11.x
  • 1.  Problem with IP Class 192.168.10.x and 192.168.11.x
    Posted Dec 19, 2014 09:29 AM
    Hello everyone,
    I need your help, I have installed 5 IAP-93 on my network, the LAN configuration is 10.10.X.X / 16, with default VLAN.
    Everything is ok, until suddenly my friend made a mistake by changing the IP alias on a notebook with IP 192.168.10.31/24, and my network is down. Then I check using wireshark and I find that the traffic is fully filled with LLMNR / NBNS of my friends notebook.
    After a few days, I tried the same thing as my friend did, and the result is, when I turn off / disconnect all IAP-93 from the network, there is no problem with IP 192.168.10.31 or 192.168.11.x on my network, so I concluded, there is a problem with my IAP-93.
    Please help me to solve the problem, what is wrong with my IAP-93. Is there any correlation with Magic VLAN?
    Note, IAP-93 is configured as a standalone AP.
    Thank you.
  • 2.  RE: Problem with IP Class 192.168.10.x and 192.168.11.x
    Posted Dec 19, 2014 09:48 AM
    Here is my configuration :
    version 6.1.3.0-3.1.0
    virtual-controller-country SG
    virtual-controller-key 9c8888d30122e0e9e42ef5391dc6dc2f48251501eddee678e6
    name ACP11-1
    virtual-controller-ip 10.10.50.82
    terminal-access
    ntp-server 10.10.0.51
    clock timezone Jakarta 07 00
    rf-band 2.4
    allow-new-aps
    allowed-ap d8:c7:c8:c8:8b:04
    allowed-ap d8:c7:c8:c8:8b:20
    allowed-ap d8:c7:c8:c8:8b:0c
    arm
    wide-bands 24ghz
    g-channels 6
    min-tx-power 3
    max-tx-power 127
    band-steering-mode disable
    air-time-fairness-mode fair-access
    client-aware
    scanning
    syslog-level warn ap-debug
    syslog-level warn network
    syslog-level warn security
    syslog-level warn system
    syslog-level warn user
    syslog-level warn user-debug
    syslog-level warn wireless
    user 1c659da23bd8 2c5b3ae2921fe0f4c51ab169fb722cfa0156f600d623a59b radius
    user 0017c41a1998 e90ba7f0e792071e4e37b94fca7f414fa7009ca32c0e42b1 radius
    user 001f3b0b06dd 99d69afb8124fa2b185ee79820a107a64679f4ebfb378815 radius
    user 889ffa0b70e0 86c2cdd20d75a401c99e502490b8397adafcb54724ace334 radius
    mgmt-user admin bc3be3a28338276bb378a9c7432ef042b8a1f1c0494e6520
    wlan access-rule default_wired_port_profile
    rule any any match any any any permit
    wlan access-rule SIM-AN
    wlan access-rule default_dev_rule
    wlan ssid-profile SIM-AN
    index 0
    type employee
    essid SIM-AN
    wpa-passphrase 3a92121734a5de57c49f828926c7daa6561b72fefa2b1845
    opmode wpa-psk-tkip,wpa2-psk-aes
    max-authentication-failures 0
    vlan 1
    rf-band 2.4
    captive-portal disable
    dtim-period 1
    inactivity-timeout 1000
    broadcast-filter none
    blacklist
    dmo-channel-utilization-threshold 90
    enet-vlan guest
    wlan captive-portal
    background-color 16777215
    banner-color 16777215
    banner-text "Welcome to the Guest Network."
    terms-of-use "Please read and accept terms and conditions and then login."
    use-policy "This network is not secure and use it at your own risk."
    authenticated
    wlan external-captive-portal
    server localhost
    port 80
    url "/"
    auth-text "Authenticated"
    blacklist-time 60
    auth-failure-blacklist-time 60
    blacklist-client e0:91:53:39:ea:b9
    blacklist-client 18:20:32:72:eb:d6
    blacklist-client 10:78:d2:e2:15:fe
    ids
    wireless-containment none
    wired-port-profile default_wired_port_profile
    switchport-mode trunk
    allowed-vlan all
    native-vlan 1
    shutdown
    access-rule-name default_wired_port_profile
    speed auto
    duplex full
    no poe
    type employee
    enet0-port-profile default_wired_port_profile
    enet1-port-profile default_wired_port_profile
    enet2-port-profile default_wired_port_profile
    uplink
    preemption
    enforce none
    l3-mobility
  • 3.  RE: Problem with IP Class 192.168.10.x and 192.168.11.x
  • 4.  RE: Problem with IP Class 192.168.10.x and 192.168.11.x
    Posted Dec 19, 2014 09:56 AM
    Here is my result :
    d8:c7:c8:c8:8b:20# show dhcp-allocation
    ---------------------/etc/dnsmasq.conf--------------------
    listen-address=127.0.0.1
    addn-hosts=/etc/ld_eth_hosts
    addn-hosts=/etc/ld_ppp_hosts
    dhcp-src=192.168.10.1
    dhcp-leasefile=/tmp/dnsmasq.leases
    dhcp-authoritative
    filterwin2k
    #magic-vlan
    vlan-id=3333
    dhcp-range=192.168.10.3,192.168.11.254,255.255.254.0,12h
    dhcp-option=1,255.255.254.0
    dhcp-option=3,192.168.10.1
    dhcp-option=6,10.10.0.37
    dhcp-option=54,192.168.10.1
    ---------------------/tmp/dnsmasq.leases------------------
  • 5.  RE: Problem with IP Class 192.168.10.x and 192.168.11.x
    Posted Dec 19, 2014 10:13 AM
    Edit
  • 6.  RE: Problem with IP Class 192.168.10.x and 192.168.11.x
    Posted Dec 19, 2014 12:48 PM
    You can change it in the dhcp options to be whatever you want/need.
  • 7.  RE: Problem with IP Class 192.168.10.x and 192.168.11.x
    Posted Dec 22, 2014 09:02 PM
    OK thanks for your help, i realy appreciate.
    Is it possible to disabled?
