Wired Intelligent Edge
Problem with LACP between Aruba 3810m and Juniper EX4600
This thread has been viewed 40 times
  • 1.  Problem with LACP between Aruba 3810m and Juniper EX4600
    Posted Feb 16, 2023 03:08 AM
    Last week I setup a LACP connection between an Aruba 3810m and a Juniper EX4600. This LACP was made up of four optical fibers.
    This is my configuration on Aruba 3810m:
    trunk 1/A1-1/A2,2/A1-2/A2 trk1  lacp
    interface 1/A1
         name "1 - LACP to EX4600"
         exit
    interface 1/A2
         name "2 - LACP to EX4600"
         exit
    interface 2/A1
         name "3 - LACP to EX4600"
         exit
    interface 2/A2
         name "4 - LACP to EX4600"
         exit
    interface Trk1
         tagged vlan 10,15,100,200
         untagged vlan 1
         spanning-tree priority 4
         exit
    This is my configuration on Juniper EX4600:
    interface {
         xe-2/0/14 {
              description "ae10 LACP to 3810m"
              ether-options {
                   802.3ad ae10;
         xe-3/0/14 {
              ether-options {
                   802.3ad ae10;
         xe-4/0/14 {
              ether-options {
                   802.3ad ae10;
         xe-5/0/14 {
              ether-options {
                   802.3ad ae10;
         ae10 {
              description "LACP to 3810m"
              aggregated-ether-options {
                   lacp {
                        passive;
                        periodic fast;
              unit 0 {
                   family ethernet-switching {
                        interface-mode trunk;
                        vlan {
                             members [ v0010 v0015 v0100 v0200 ];
    When I connect three links out of four - LACP woks fine. But when I connect all links, it's LACP not working properly.
    I observe symptoms of not working properly such as: host unreachable, packet loss and inability to connect some access devices (PC, CCTV, etc.).  Additionally, only part of the AP loses connection with the Aruba 7210 controller.
    As I wrote earlier, if I disable just one connection out of four it all starts working fine.
    4x10G (UP) -> connection not working properly
    3x10G (UP) + 1x10G (DOWN) -> connection working fine
    2x10G (UP) + 2x10G (DOWN) -> connection working fine
    1x10G (UP) + 3x10G (DOWN) -> connection working fine
    Image Version:
    Aruba 3810m: KB.16.09.0022
    Juniper EX4600: JunOS 19.4R2.6
    My topology:
    access switches 2930f --> 3810m --> EX4600 --> Router  --> ISP
    AP -> access switch 2930f ---------------\
    IP Phone -> access switch 2930f -------+------> 3810m ------> EX4600 <----- Aruba 7210
    PC etc. -> access switch 2930f ---------/
  • 2.  RE: Problem with LACP between Aruba 3810m and Juniper EX4600
    MVP GURU
    Posted Feb 16, 2023 06:42 AM
    Hi! diagnostic Aruba 3810M side (show lacp and show trunk about that 4x10G Port Trunk logical interface plus a good show logging -r too) when you connect (or enable, if you start with all ports disabled) first, second, third and finally fourth physical fiber optic link to your Firewall?
    Could you also post show tech transceivers (Aruba side). Juniper side I believe you can also easily connect real time diagnostic/status about those xe ports and the ae logical bond.
  • 3.  RE: Problem with LACP between Aruba 3810m and Juniper EX4600
    Posted Feb 16, 2023 03:34 PM
    Do you by chance have the aggregated device count set to 3?
    Example for reference.
    chassis {
        redundancy {
            graceful-switchover;
        aggregated-devices {
            ethernet {
                device-count 2;
  • 4.  RE: Problem with LACP between Aruba 3810m and Juniper EX4600
    MVP GURU
    Posted Feb 16, 2023 04:03 PM
    Doesn't that parameter (device-count) on the chassis section (set aggregated-devices ethernet device-count 2) define the "number of LAGs to be created on the chassis" and not the number of physical member interfaces belonging to the specific LAG ae10?
  • 5.  RE: Problem with LACP between Aruba 3810m and Juniper EX4600
    Posted Feb 20, 2023 03:43 AM
    This  is my log from 3810m:
    show logging -r
    I 02/16/23  14:13:03 00076 ports: ST1-CMDR: port 1/A2 in Trk1 is now on-line
    I 02/16/23  14:13:03 00435 ports: ST1-CMDR: port 1/A2 is Blocked by STP
    I 02/16/23  14:13:00 00435 ports: ST1-CMDR: port 1/A2 is Blocked by LACP
    I 02/16/23  14:12:49 00077 ports: ST1-CMDR: port 1/A2 in Trk1 is now off-line
    I 02/16/23  14:05:05 00076 ports: ST1-CMDR: port 1/A2 in Trk1 is now on-line
    I 02/16/23  14:05:05 00435 ports: ST1-CMDR: port 1/A2 is Blocked by STP
    I 02/16/23  14:05:02 00435 ports: ST1-CMDR: port 1/A2 is Blocked by LACP
    I 02/16/23  14:04:50 00077 ports: ST1-CMDR: port 1/A2 in Trk1 is now off-line
    I 02/16/23  13:55:42 00076 ports: ST1-CMDR: port 1/A2 in Trk1 is now on-line
    I 02/16/23  13:55:42 00435 ports: ST1-CMDR: port 1/A2 is Blocked by STP
    I 02/16/23  13:55:38 00435 ports: ST1-CMDR: port 1/A2 is Blocked by LACP
    show lacp
    1/A1  Active  Trk1   Up  Yes  Success  0  978
    1/A2  Active  Trk1   Up  Yes  Success  0  978
    2/A1  Active  Trk1   Up  Yes  Success  0  978
    2/A2  Active  Trk1   Up  Yes  Success  0  978
    show trunk
    1/A1  | Ex4600   SFP+LR  | Trk1  LACP
    1/A2  | Ex4600   SFP+LR  | Trk1  LACP
    2/A1  | Ex4600   SFP+LR  | Trk1  LACP
    2/A2  | Ex4600   SFP+LR  | Trk1  LACP
  • 6.  RE: Problem with LACP between Aruba 3810m and Juniper EX4600
    Posted Feb 20, 2023 07:27 AM
    Hi
    did you check interface statistics ("show interface <port>") for any errors or discards?
    What happened between 14:05:05 and 14:12:49 as well as between 13:55:42 and 14:04:50? Did you disconnect anything or change any configuration? Or was this out of nothing and may be a root cause of your problem?
    Another one: Does is make a difference which of the 4 links you disconnect in order to have a stable connection? Can you disable ANY of the 4 or do you have to disconnect a specific one?
    LACP seems to have established a good partnership with the other side, however, could you please also get the output of the following commands:
    • show lacp local
    • show lacp peer
    Did you check interface and LACP status on the Juniper side as well? Does it show any strange behavior?
    Thomas
  • 7.  RE: Problem with LACP between Aruba 3810m and Juniper EX4600
    Posted Feb 22, 2023 03:23 AM
    show lacp local
    1/A1  Trk1  Active  Yes  Slow  No  b8s4**-******
    1/A2  Trk1  Active  Yes  Slow  No  b8s4**-******
    2/A1  Trk1  Active  Yes  Slow  No  b8s4**-******
    2/A2  Trk1  Active  Yes  Slow  No  b8s4**-******
    show lacp peer
    1/A1  Trk1  e4fc**-******  69  127  0  17  Passive  Slow
    1/A2  Trk1  e4fc**-******  81  127  0  17  Passive  Slow
    2/A1  Trk1  e4fc**-******  68  127  0  17  Passive  Slow
    2/A2  Trk1  e4fc**-******  80  127  0  17  Passive  Slow
    The problem with LACP is on the Juniper EX4600 side. For now, Juniper support is trying to fix the problem.
  • 8.  RE: Problem with LACP between Aruba 3810m and Juniper EX4600
    Posted Feb 23, 2023 04:23 AM
    Why is LACP at the Juniper side configured as passive?
    Could you try
    set ae10 aggregated-ether-options lacp active
    Like pernassus was mentioning, please raise the number of supported AE's at the juniper side.
    For example
    set aggregated-devices ethernet device-count 5
    William Bargeman
    Systems Engineer Aruba
  • 9.  RE: Problem with LACP between Aruba 3810m and Juniper EX4600
    Posted Mar 02, 2023 08:02 AM
    I set up: "set aggregated-devices ethernet device-count 32"
    Because when I set up active, it only 2 links work properly.
    3x10G (UP) + 1x10G (DOWN) -> connection not working properly
