Networking Jobs
last person joined: 15 days ago
Are you seeking a Networking Engineering job? Do you have a Networking Engineering job opening? If so, use this section to post your resume or to post your job openings.
Problem with option 43 on Aruba-CX
This thread has been viewed 59 times
  • 1.  Problem with option 43 on Aruba-CX
    Posted Nov 26, 2020 11:56 AM
    Hi All,
    Have Aruba-CX 8320 switch with dhcp configured on it. DHCP should provide controller IP for AP 315 via option 43 (ascii IP), but it doesn't. How to configure option 43 on this switch? I allready tried do it via ip, ascii and hex - but without success.
    AP still runs as a IAP.
    Regards
    MB
    Maciej Brodzinski
  • 2.  RE: Problem with option 43 on Aruba-CX
    MVP EXPERT
    Posted Nov 27, 2020 10:01 AM
    Hi Maciej,
    Use option 43 and 60 togehter.
    Option 43 have the attribute the IP of your controller
    Option 60 have the attribute "ArubaAP"
    For what i understand from the manual it must be something like this.
    switch(config)# dhcp-server vrf primary
    switch(config-dhcp-server)# pool primary-pool
    switch(config-dhcp-server-pool)# option 3 ip 192.168.1.1
    Hope this helps you!
    Marcel Koedijk | MVP Expert 2020 | ACMP | ACCP | Ekahau ECSE
  • 3.  RE: Problem with option 43 on Aruba-CX
    Posted Nov 29, 2020 04:36 PM
    Hi Marcel,
    Already did that. The solution is somewhere else. I found that there was no info in ap logs about getting option 43 from dhcp. A little reading...and...
    Some model, with universal, runs a cl mode (controller less) and they skip dhcp option 43 from dhcp. They can be provisioned from activate for example. - did this and it helps.
    Regards
    MB
    Maciej Brodzinski
  • 4.  RE: Problem with option 43 on Aruba-CX
    MVP EXPERT
    Posted Nov 29, 2020 04:49 PM
    Hi Maciej,
    Good it worked now, thanks for the feedback.
    Below the flowchart of the boot process of a Unified AP. Should be done the DHCP based discovery before getting into instant controller mode.
  • 5.  RE: Problem with option 43 on Aruba-CX
    Posted Nov 29, 2020 04:54 PM
    Look at this (attachment).
    Maciej Brodzinski
  • 6.  RE: Problem with option 43 on Aruba-CX
    MVP EXPERT
    Posted Nov 29, 2020 06:44 PM
    Hi Maciej,
    My slide is from the ACMX training guide and it's true for every out-of-the-box or factory default Unified AP.
    Don't know the source of your slide but it's possible true when your Unified AP is already deployed in instant cluster mode before.
    When have issues with AP deployment it's recommended to perform a factory-reset from the CLI.
