Problem with RAP
  • 1.  Problem with RAP
    Posted Sep 05, 2017 06:36 AM
    I have problem with setup my RAP. Remotely and even with convert campus to remote AP.
    I allow L2TP (PAP) in Advanced Services > VPN Services > IPSEC
    then configure L2TP pool and set IKE Shared Secrets key
    In remote convert I add APs mac address to whitelist. In campus i read that I dont need to.
    In remote it showed vpn setup failed. In campus after I reconnect AP to different LAN AP didn't show in AP installation.
    Then I tried port scan to my controller public IP to port 4500. And it show that port is closed. So I checked Advanced Services > Stateful Firewall > ACL White List
    and port 4500 UDP is permit for any IP.  Or I must allow this port elsewhere ?
    Thanks for advice. Srry for my english.
  • 2.  RE: Problem with RAP
    Posted Sep 05, 2017 07:40 AM
    Hi TomasD,
    Is the traffic going through a firewall? Maybe the firewall is blocking the ports. Can you please share more details about the environment?
    what happened, if you place the AP directly into a VLAN which can directly communicate with the controller? Without any firewalls in between.
    Many thanks,
    Florian
  • 3.  RE: Problem with RAP
    Posted Sep 06, 2017 09:03 AM
    Thanks for reply. Now I have open UDP port 4500 on my controller, but nothing change. RAP cant connect to controller. Still get VPN connect failed.
    Any other idea? Thanks
  • 4.  RE: Problem with RAP
    Posted Sep 06, 2017 09:06 AM
    Hi TomasD,
    Ports needed between RAP and Mobilty Controller:
    • IPSec (UDP ports 500 and 4500)
    Not only UDP 4500 but also 500 is needed. Can you check this as well.
  • 5.  RE: Problem with RAP
    Posted Sep 06, 2017 09:51 AM
    yes port 500 was open too.
    500/udp open|filtered isakmp
  • 6.  RE: Problem with RAP
    Posted Sep 07, 2017 07:39 AM
    Hi ThomasD,
    How is the RAP configured to find the controller? If you enter the "apboot" menu and use the command "printenv", you should find an entry like "master=IP OR DNS OF MASTER". If this is not present, the RAP is not able to find the master.
    If you have this entry, I would try to trace the traffic of the RAP to see if he is actually sending requests to the controller. Just to make sure, he is doing something.
  • 7.  RE: Problem with RAP
    Posted Oct 16, 2017 01:38 AM
    so problem was in authentication.
    Security > Authentication > L3 Authentication / VPN Authentication
    ServerGroup in default-rap must be setup on internal db. I didn't have that.
