last person joined: 10 hours ago
Problem with Samsung Galaxy SIII Phones and 802.1x
  • 1.  Problem with Samsung Galaxy SIII Phones and 802.1x
    Posted Nov 15, 2012 02:26 PM
    I am having trouble with 802.1x Authentication on Samsung Galaxy SIII Smart Phones.
    After setting the wireless settings on the phone it can take numerous tries before the device will connect.
    Each failed attempt is according to the phone due to an authentication error but without making any changes to the settings and simply touching the connect button again and again, the device will eventually connect.  There is no record of an Authentication error on My RADIUS Servers. There isn't even a log entry for the Authentication attempt so this implies that the controller does not forward the auth request to the RADIUS server and leads me to think the problem is likely with the 802.1x profile on my controllers.
    Thing is that this only seems to be happening with Android devices.
    This specific phone is a "MUST FIX" because we have deployed a couple of hundred of them across our organization.
    Anyone had any similar experiences with the Galaxy SIII (Samsung SGH-I747M)? Better yet, anyone have a solution???
    Thanks in advance.
  • 2.  RE: Problem with Samsung Galaxy SIII Phones and 802.1x
    Posted Nov 15, 2012 03:54 PM
    Similar experience with my own Samsung S3 on our 802.1x network as well.
    The only thing I can possibly think of is to enable the "Validate PMKID" option but I don't want to turn that on as I am the only one out of 600 users who connects their phone to the corporate wireless, and that's really only for testing when I am at another site to make sure the vlans are correct, etc.
  • 3.  RE: Problem with Samsung Galaxy SIII Phones and 802.1x
    Posted Nov 16, 2012 06:28 PM
    I see this effect too but only the Sprint phones of this flavor do this...
    Also, a few other Sprint Android phones will not connect to save their life.
    We use Windows 2008 as our .1x security
  • 4.  RE: Problem with Samsung Galaxy SIII Phones and 802.1x
    Posted Nov 16, 2012 07:11 PM
    Please open a TAC case so that they can get the specifics of your deployment.  They can seek and uncover details that would take a great deal of time on this forum.
  • 5.  RE: Problem with Samsung Galaxy SIII Phones and 802.1x
    Posted Nov 26, 2012 09:00 AM
    Opened a TAC with both Aruba and Samsung.
    Samsung tells me that Telus Mobility, whom we have our S3's with will be pushing out an update over the next couple of days.
    This update is supposed to solve a number of issues so hopefully roaming on 802.1x networks will be one of the  fixes.
  • 6.  RE: Problem with Samsung Galaxy SIII Phones and 802.1x
    Posted Dec 06, 2012 06:59 AM
    We have updated the OS on our Galaxy S III phones to JellyBean.
    This has solved the problem.
  • 7.  RE: Problem with Samsung Galaxy SIII Phones and 802.1x
    Posted Apr 29, 2013 09:56 PM
    Sorry for re-opening this post.  We don't use 802.1x but we are also encountering the same sympthom. The phone just won't connect and will just say Authentication error of some sort. However, this happens intermittently. This never happen to any of our iOS devices.
    Here's the phone info:
    Samsung Galaxy S3
    Model Number: GTI9300
    Android Version: 4.1.2
    Baseband version: I9300XXELLA
    Aruba Setup:
    AP135, with WPA2 PSK
  • 8.  RE: Problem with Samsung Galaxy SIII Phones and 802.1x
    Posted Apr 30, 2013 10:23 AM
    Samsung Galaxy S3
    Aruba Setup:
    McArenas,
    Please disable band-steering and spectrum load balancing to rule out poor coverage.
  • 9.  RE: Problem with Samsung Galaxy SIII Phones and 802.1x
    Posted Apr 29, 2013 10:25 PM
    How long is the preshared key ?
  • 10.  RE: Problem with Samsung Galaxy SIII Phones and 802.1x
    Posted Apr 29, 2013 10:31 PM
    18 chars long.
    I switched to a different SSID, with a shorter PSK, (10 chars), but still same problem.
  • 11.  RE: Problem with Samsung Galaxy SIII Phones and 802.1x
    Posted Apr 29, 2013 10:53 PM
    what can see when you run the show auth-tracebuf ?
  • 12.  RE: Problem with Samsung Galaxy SIII Phones and 802.1x
    Posted Apr 29, 2013 11:19 PM
    Here an actual screenshot:
    when a successful connection was made:
    auth trace
    Here's the screenshot from the phone during error and during an error, there is nothing on the auth trace log with the specific mac address.
    Galaxy S3 error
  • 13.  RE: Problem with Samsung Galaxy SIII Phones and 802.1x
    Posted Apr 30, 2013 09:45 AM
    Have you removed any of the lower data rates under the SSID ? sometimes some devices don't like that.
    What code are you running ?
    Do you see anything in the logs ? logging level debugging user-debug <device mac address>
  • 14.  RE: Problem with Samsung Galaxy SIII Phones and 802.1x
    Posted May 01, 2013 07:31 PM
    Here's a screencap of a particular SSID profile:
    Sorry I didn't quite get it... which code?
    How do I enable debugging level logging in our controllers?
    Also, where can I read about the meaning of all those settings? Again, thanks for your guidance.
    thanks,
    M
  • 15.  RE: Problem with Samsung Galaxy SIII Phones and 802.1x
    Posted May 01, 2013 07:43 PM
    I meant the AOS code version you are running
    (controller) #show version
    ArubaOS (MODEL: Aruba7240-US), Version 6.2.0.3
    (controller) (config) #logging level debugging user-debug <device mac address>
    and then to view the logs generated :
    (controller) #show logs user-debug all | include <device mac address>
    Here's more info on how to debug:
    http://www.arubanetworks.com/techdocs/ArubaOS_61/ArubaOS_61_CLI/logging.htm
    https://arubanetworkskb.secure.force.com/pkb/articles/HowTo/R-1119
    https://arubanetworkskb.secure.force.com/pkb/articles/HowTo/R-1155
  • 16.  RE: Problem with Samsung Galaxy SIII Phones and 802.1x
    Posted May 01, 2013 07:46 PM
    thanks for your patience Victor. Here's our AOS version:
    ArubaOS (MODEL: Aruba6000), Version 6.1.3.3
    M
  • 17.  RE: Problem with Samsung Galaxy SIII Phones and 802.1x
    Posted May 01, 2013 07:50 PM
    I have attached the Aruba User guide which explains most of those settings. (page 155)
    You can find all this info in the Aruba support site :
    http://support.arubanetworks.com/DOCUMENTATION/
  • 18.  RE: Problem with Samsung Galaxy SIII Phones and 802.1x
    Posted May 01, 2013 08:10 PM
    Here's the log when it won't connect:
  • 19.  RE: Problem with Samsung Galaxy SIII Phones and 802.1x
    Posted May 01, 2013 08:48 PM
    McArenas,
    Like I said before, PLEASE turn off Spectrum Load Balancing or Band Steering.  The Samsung might not like the deauth.  "Resource Constrained" is Spectrum Load Balancing or Band Steering activity.
  • 20.  RE: Problem with Samsung Galaxy SIII Phones and 802.1x
    Posted May 01, 2013 11:52 PM
    @cjoseph wrote:
    McArenas,
    Thank you so much!  That fixed the problem.  I appreciate all the help!
  • 21.  RE: Problem with Samsung Galaxy SIII Phones and 802.1x
    Posted May 01, 2013 08:54 PM
    Thanks! As additional note I have noticed that this problem is only happening to a room with an AP135. I tried to roam in other classrooms with other AP models. 61, 121 and 105, samsung connects without s problem.
    I will try to turn off load and spectrum balancing as suggested. Thanks!
  • 22.  RE: Problem with Samsung Galaxy SIII Phones and 802.1x
    Posted May 01, 2013 08:55 PM
    That was Spectrum Load Balancing in the Radio Profile and Band Steering in the Virtual AP profile.
