last person joined: 7 hours ago
Problem with SMS messaging in ClearPass Guest in CPPM 6.4
  • 1.  Problem with SMS messaging in ClearPass Guest in CPPM 6.4
    Posted Sep 22, 2014 11:42 AM
    When I was running CPPM 6.3.4 I configured clearpass guest to email the guest user their  credentials and to also sms  them using Bulk SMS UK. This all worked just fine and dandy. I then upgraded  to CPPM 6.4 and although guest users can self register themselves ( this is a sponsored guest service) and receive an email from our ClearPass server with their credentials, there's no sign of an SMS messsge.
    I've checked the register page I created and it defintiely  says send credentials to user via SMS
    I can log onto the CPPM server and send an SMS to a mobile tel no,
    It's just when a user performs a self registration that there seems to be an issue with sending an SMS message.
    Any logs I can check to see if there are some eror messages?
    Rgds
    Alex
  • 2.  RE: Problem with SMS messaging in ClearPass Guest in CPPM 6.4
    Posted Sep 23, 2014 02:54 AM
    Look in guest side under
    Home » Administration » Support » Application Log
    You will see an event when the email and Txt is being sent.
    You may need to also enable debuging for guest. Just make sure you turn it off when you are done testing.
  • 3.  RE: Problem with SMS messaging in ClearPass Guest in CPPM 6.4
    Posted Sep 23, 2014 05:16 AM
    Sigh!
    Greater than 160 chars in SMS message
    Problem fixed
  • 4.  RE: Problem with SMS messaging in ClearPass Guest in CPPM 6.4
    Posted May 27, 2016 05:03 AM
    Hi Troy,
    Where can I find the debug information from that plugin?
    Kind regards,
    Jeroen
