Problem with the Centralized Licensing
  • 1.  Problem with the Centralized Licensing
    Posted Oct 03, 2016 03:13 PM
    After activating the option of centralized licenses, I have some APs in local controllers with flags IL, and does not work provisioned again.
    Any idea about this?
  • 2.  RE: Problem with the Centralized Licensing
    Posted Oct 03, 2016 03:28 PM
    For each of your controllers, what is the output of :
    show license profile
    show license server-table
    show license-usage client
  • 3.  RE: Problem with the Centralized Licensing
    Posted Oct 03, 2016 03:42 PM
    Master Controller:
    (MX-INT-P3-MDF-CTRLR-MASTER) #show license profile
    License provisioning profile
    Parameter Value
    Centralized Licensing Enabled
    (MX-INT-P3-MDF-CTRLR-MASTER) #show license-usage client
    License Clients License Usage
    Hostname IP Address AP Lic. Used PEF Lic. Used RF Protect Lic. Used xSec Lic. Used ACR Lic. Used Last update (secs. ago)
    MX-INT-P3-MDF-CTRLR-MASTER 10.34.X.X 14 22 21 0 0 12
    MX-TOL-UW-PB-MDF-CTRLR-LOCAL 10.34.X.X 0 2 2 0 0 13
    GT-MIX-PB-MDF-CTRLR-LOCAL 10.34.X.X 5 5 5 0 0 7
    MX-SAL-MDF-PB-CTRLR-LOCAL 10.34.X.X 6 6 6 0 0 26
    MX-TOL-AI-PB-MDF-CTRLR-LOCAL 10.34.X.X 4 12 12 0 0 21
    MX-ECA-P1-MDF1-CTRLR-LOCAL 10.34.X.X 4 4 4 0 0 25
    MX-INT-P3-MDF-CTRLR-LOCAL 10.34.X.X 8 16 16 0 0 17
    DO-SDQ-P4-MDF-CTRLR-LOCAL 10.149.X.X 1 0 0 0 0 0 22
    MX-VAL-P1-MDF-CTRLR-LOCAL 10.34.X.X 1 1 1 0 0 19
    GT-GUA-P15-MDF-CTRLR-LOCAL 10.148.X.X  8 8 8 0 0 2
    MX-TL2-PB-MDF-CTRLR-LOCAL 10.34.X.X 2 2 2 0 0 16
    Total AP Licenses Used :52
    Total PEF Licenses Used :78
    Total RF Protect Licenses Used :77
    Total XSEC Licenses Used :0
    Total ACR Licenses Used :0
    Total no. of clients :11
    (MX-INT-P3-MDF-CTRLR-MASTER) #show license server-table
    License Server Table
    Service Type Aggregate Lic. Used Lic. Remaining Lic.
    Access Points 82 52 30
    Next Generation Policy Enforcement Firewall Module 128 78 50
    RF Protect 48 77 0
    xSec Module 0 0 0
    Advanced Cryptography 0 0 0
    Parameter Value
    LOCAL:
    (DO-SDQ-P4-MDF-CTRLR-LOCAL) #show license profile
    Parameter Value
    (DO-SDQ-P4-MDF-CTRLR-LOCAL) #show license server-table
    This command is applicable only on the license server
    (DO-SDQ-P4-MDF-CTRLR-LOCAL) #show license-usage client
  • 4.  RE: Problem with the Centralized Licensing
    Posted Oct 03, 2016 04:22 PM
    Numbers seem to add up in "show license-usage client" & "show license server-table"
    What are the actual # of installed licenses on each of your controllers?  show license
    Make sure your local (clients) are pointing to the correct (server) :  show license debug
    Are there any entiries in the logs pertaining to those APs that are not licensed?  Are those APs terminating on the same local controller, or different ones?
    --Raf
  • 5.  RE: Problem with the Centralized Licensing
    Posted Oct 03, 2016 05:24 PM
    That is the output in the local controller
    (MX-TOL-UW-PB-MDF-CTRLR-LOCAL) #show license
    License Table
    Key Installed Expires Flags Service Type
    14:24:07
    License Entries: 1
    Flags: A - auto-generated; E - enabled; R - reboot required to activate
    That is the output to the master controller
    Do you know the way to disable this option and that each controller manage the licences locally?
  • 6.  RE: Problem with the Centralized Licensing
    Posted Oct 03, 2016 06:17 PM
    Please edit this post and remove all your license keys .
    Based on the outputs you shared , it looks like you may need  additional AP licenses
  • 7.  RE: Problem with the Centralized Licensing
    Posted Oct 03, 2016 06:20 PM
    Hi Victor
    Is possible do roll back to this action, in order to that each controller manage yours own licence again?
  • 8.  RE: Problem with the Centralized Licensing
    Posted Oct 04, 2016 07:35 AM
    Hi Victor
    I think that is not related with the license numbers, because before that I enable the centralized licensing all local controllers had the enough licenses number.
    It's possible do the roll back, or there is a risk of losing some license?
