Problema Autenticacion AD WebAuth Aplicacion
  • 1.  Problema Autenticacion AD WebAuth Aplicacion
    Posted Mar 20, 2019 08:21 PM
    Hola tengo un problema con la autenticacion del portal cautivo en mi SSID , mis usuarios los tengo en mi AD y me marca un error de password, al momento de introducir mis credenciales de AD.
    Previamente ya se se integró mi ClearPass 6.7 al AD como fuente.
    Cree un Servicio de "Aruba Application Authentication"
    Cree un Source Active Directory.
    Saludos! espero me puedan ayudar
    El error es esl sigiente: anexo imagen
  • 2.  RE: Problema Autenticacion AD WebAuth Aplicacion
    Posted Mar 21, 2019 05:20 AM
    Have you joined ad to domain in clearpass and also you can try test the auth of user from CLI
    #network nslookp -q SRV <netboais name> --- To find FQDN from CPPM of AD
    #ad netjoin ---to join cppm to ad from CLI
    #ad testjoin <netbois> -- to check connection
    #ad auth-u <username> <netbois> - to test user auth with AD
  • 3.  RE: Problema Autenticacion AD WebAuth Aplicacion
    Posted Mar 21, 2019 04:15 PM
    Hola hice las pruebas pero me sigue apareciendo este error, en los Logs.
    [ajp-apr-8009-exec-3] R:W0000017d-01-5c93eecc] ERROR com.avenda.tips.webauthservice.WebAuthHandler - Failed to perform webauth, reason=PasswordMismatch
     WARN Common.MacAddrAttrProvider - HostMac missing, not populating different mac representations
    WARN Common.TagDefinitionCacheTable - Failed to build TagDefinitionMap. Unknown NadClient for Id=0
     WARN Ldap.LdapQuery - Failed to get value for attributes=memberOf]
  • 4.  RE: Problema Autenticacion AD WebAuth Aplicacion
    Posted Mar 22, 2019 05:12 AM
    Are you receiving any request in access tracker and event viewer, while you are trying to login in CPPM? Are you seeing this issue for all the clients are specific to any single client?
    Does that user details exisit in AD, it says failed to find the user, does bind user have proper permission to search the users in AD?
    Check all the details are configured properly in controller.  I would recommand to file TAC ticket.
