Forum Français
last person joined: 7 days ago
Bienvenue sur le forum communautaire français d'Airheads.
Probleme VLAN Defaut sur 2930F
  • 1.  Probleme VLAN Defaut sur 2930F
    Posted Oct 11, 2019 03:51 AM
    J'ai ouvert un topic à la mauvaise place sur le forum
    https://community.arubanetworks.com/t5/Network-Management/Probleme-VLAN-Defaut-sur-2930F-48G-4SFP/td-p/555928
    Je reposte ici
    Bonjour, j'ai un petit probleme sur un switch 2930F-48G-4SFP+
    sur lequel je n'arrive pas à me connecter sur l'interface web.
    Dans l'infra il y deux switchs identique sur un c'est Ok et sur l'autre non
    Ci-dessous les configurations de SW1 et SW2 :
    SW2 connexion possible
    ; JL254A Configuration Editor; Created on release #WC.16.03.0005
    ; Ver #10:08.3f.ff.bb.ef.7c.59.fc.6b.fb.9f.fc.ff.ff.37.ef:7e
    hostname "SW2"
    module 1 type jl254a
    ip default-gateway 10.100.200.254
    ip route 0.0.0.0 0.0.0.0 172.18.100.254
    snmp-server community "labo" unrestricted
    snmp-server contact "infra sud" location "Baie Serveur"
    vlan 1
    name "DEFAULT_VLAN"
    no untagged 25
    untagged 1-24,26-52
    ip address 10.100.200.048 255.255.255.0
    exit
    vlan 100
    name "VLAN100"
    tagged 48
    no ip address
    exit
    vlan 110
    name "VLAN110"
    tagged 25,48
    no ip address
    exit
    vlan 120
    name "VLAN120"
    tagged 48
    no ip address
    exit
    vlan 130
    name "VLAN130"
    tagged 48
    no ip address
    exit
    vlan 140
    name "VLAN140"
    no ip address
    exit
    spanning-tree
    no tftp server
    no autorun
    no dhcp config-file-update
    no dhcp image-file-update
    no dhcp tr69-acs-url
    password manager
    password operator
    SW1 connexion impossible
    hostname "SW1"
    ip default-gateway 10.200.200.254
    vlan 1
    name "DEFAULT_VLAN"
    no untagged 1-38,40,42-44,46
    untagged 39,41,45,47-52
    ip address 10.100.200.049 255.255.255.0
    exit
    vlan 100
    name "VLAN100"
    untagged 13,25
    tagged 48
    no ip address
    exit
    vlan 110
    name "VLAN110"
    untagged 1,3,5,7,9,11,15,17,19,21,23,27,29,31,33,35,37
    tagged 48
    no ip address
    exit
    vlan 120
    name "VLAN120"
    untagged 2,4,6,8,10,12,14,16,18,20,22,24,26,28,30,32,34,36,38,40,42-44,46
    tagged 48
    no ip address
    exit
    no tftp server
    no autorun
    password manager
    password operator
    Si vous pouvez me donner quelques pistes de recherches
    Merci
    #2930F
  • 2.  RE: Probleme VLAN Defaut sur 2930F
    Posted Oct 11, 2019 03:54 AM
    Bonjour,
    Est-ce qu'en CLI/SSH cela fonctionne ?
    Est-ce qu'il est globalement joignable ?
  • 3.  RE: Probleme VLAN Defaut sur 2930F
    Posted Oct 11, 2019 04:12 AM
    Je peux me connecter uniquement en console directement sur le Switch
    Je peux aussi me connecter sur l'interface web du switch si je connecte mon PC sur le switch sur le port 39 et que j'affecte une IP fixe dans la plage à mon PC.
  • 4.  RE: Probleme VLAN Defaut sur 2930F
    Posted Oct 11, 2019 04:36 AM
    Quel port utilisez-vous pour le connecter au reste de l'infrastructure ?
  • 5.  RE: Probleme VLAN Defaut sur 2930F
    Posted Oct 11, 2019 04:44 AM
    Si je comprend la configuration c'est port 48 qui permet la connexion au reste de l'infra
    j'interviens sur l'infra et je cherche à comprendre comment l'installateur à configuré les switchs ...
    Le VLAN 1 Defaut n'est pas accessible depuis les autres VLAN pour SW1
  • 6.  RE: Probleme VLAN Defaut sur 2930F
    MVP GURU
    Posted Oct 11, 2019 10:53 AM
    Bonjour,
    Pourquoi tu as une ip default-gateway & une ip route 0.0.0.0 ?
    l'IP Routing n'est pas activé ?
    tu n'as pas activé le management vlan sur le vlan 1 ?
  • 7.  RE: Probleme VLAN Defaut sur 2930F
    Posted Oct 11, 2019 11:13 AM
    la route 0.0.0.0 renvoi sur un 3 eme swicth Cisco qui va vers le routeur
    donc 0.0.0.0 pour faire une route par defaut
    le vlan 1 est a bien le management car je peux me connecter via le port 39
  • 8.  RE: Probleme VLAN Defaut sur 2930F
    MVP GURU
    Posted Oct 11, 2019 12:00 PM
    Il y a une erreur dans ton ip default gateway
    10.200.200.254 => 10.100.200.254
    Il faudrait aussi supprimer ta route en 0.0.0.0
  • 9.  RE: Probleme VLAN Defaut sur 2930F
    Posted Oct 30, 2019 02:43 PM
    Meme avec la correction de la gateway ça ne fonctionne pas
  • 10.  RE: Probleme VLAN Defaut sur 2930F
    MVP GURU
    Posted Oct 30, 2019 06:38 PM
    c'est quoi ta configuration maintenant ?
