Wired Intelligent Edge
Problems Aruba 2930M with SFP-LX
  • 1.  Problems Aruba 2930M with SFP-LX
    Posted Jul 03, 2019 07:50 AM
    Hi everyone,
    I have two Aruba 2930M 24p and I'm making fiber optic connection test between them with two transceiver 1000LX given by Aruba. The following configuration works correctly with copper ethernet port but when I put inside the SFP transceivers the Link Status goes down. I'm wondering what I'm doing incorrectly.
    Thank you in advance.
    Test performed
    [SW A]   ------   [8km simulator fiber optic coil]   -----   [SW B]
    Configuration Switch A
    interface 24
    speed-duplex 1000-full
    exit
    snmp-server community "public" unrestricted
    oobm
    ip address dhcp-bootp
    exit
    vlan 1
    name "DEFAULT_VLAN"
    no untagged 24
    untagged 1-23
    exit
    vlan 900
    name "Test_SFP"
    tagged 24
    ip address 10.10.10.1 255.255.255.0
    exit
    Configuration Switch B
    interface 24
    exit
    oobm
    exit
    vlan 1
    name "DEFAULT_VLAN"
    no untagged 24
    untagged 1-23
    exit
    vlan 900
    name "Test_SFP"
    tagged 24
    ip address 10.10.10.2 255.255.255.0
    exit
    Report Switch A
    Aruba-2930M-24G# sh tech transceivers
    Cmd Info : show tech transceivers
    transceivers
    Transceiver Technical Information:
    Port # | Type | Prod # | Serial # | Part #
    24 | 1000LX | J4859C | DBLBW30 | 1990-3657
    show time
    Thu Jul 4 05:38:27 2019
    === The command has completed successfully. ===
    Aruba-2930M-24G# sh inter trans 24 det
    Transceiver in 24
    Interface Index : 24
    Type : 1000LX
    Model : J4859C
    Connector Type : LC
    Wavelength : 1310nm
    Transfer Distance : 10.0km (9um),
    Diagnostic Support : DOM
    Serial Number : DBLBW30
    Status
    Temperature : 25.382C
    Voltage : 3.2880V
    Tx Bias : 13.150mA
    Tx Power : 0.1012mW, -9.948dBm
    Rx Power : 0.0517mW, -12.865dBm
    Aruba-2930M-24G# sh inter brief
    Status and Counters - Port Status
    | Intrusion MDI Flow Bcast
    Port Type | Alert Enabled Status Mode Mode Ctrl Limit
    1 100/1000T | No Yes Down 1000FDx Auto off 0
    2 100/1000T | No Yes Down 1000FDx Auto off 0
    3 100/1000T | No Yes Down 1000FDx Auto off 0
    4 100/1000T | No Yes Down 1000FDx Auto off 0
    5 100/1000T | No Yes Down 1000FDx Auto off 0
    6 100/1000T | No Yes Down 1000FDx Auto off 0
    7 100/1000T | No Yes Down 1000FDx Auto off 0
    8 100/1000T | No Yes Down 1000FDx Auto off 0
    9 100/1000T | No Yes Down 1000FDx Auto off 0
    10 100/1000T | No Yes Down 1000FDx Auto off 0
    11 100/1000T | No Yes Down 1000FDx Auto off 0
    12 100/1000T | No Yes Down 1000FDx Auto off 0
    13 100/1000T | No Yes Down 1000FDx Auto off 0
    14 100/1000T | No Yes Down 1000FDx Auto off 0
    15 100/1000T | No Yes Down 1000FDx Auto off 0
    16 100/1000T | No Yes Down 1000FDx Auto off 0
    17 100/1000T | No Yes Down 1000FDx Auto off 0
    18 100/1000T | No Yes Down 1000FDx Auto off 0
    19 100/1000T | No Yes Down 1000FDx Auto off 0
    20 100/1000T | No Yes Down 1000FDx Auto off 0
    21 100/1000T | No Yes Down 1000FDx Auto off 0
    22 100/1000T | No Yes Down 1000FDx Auto off 0
    23 100/1000T | No Yes Down 1000FDx Auto off 0
    24 1000LX | No Yes Down 1000FDx NA off 0
    Aruba-2930M-24G# sh inter config
    Port Settings
    Port Type | Enabled Mode Flow Ctrl MDI
    1 100/1000T | Yes Auto Disable Auto
    2 100/1000T | Yes Auto Disable Auto
    3 100/1000T | Yes Auto Disable Auto
    4 100/1000T | Yes Auto Disable Auto
    5 100/1000T | Yes Auto Disable Auto
    6 100/1000T | Yes Auto Disable Auto
    7 100/1000T | Yes Auto Disable Auto
    8 100/1000T | Yes Auto Disable Auto
    9 100/1000T | Yes Auto Disable Auto
    10 100/1000T | Yes Auto Disable Auto
    11 100/1000T | Yes Auto Disable Auto
    12 100/1000T | Yes Auto Disable Auto
    13 100/1000T | Yes Auto Disable Auto
    14 100/1000T | Yes Auto Disable Auto
    15 100/1000T | Yes Auto Disable Auto
    16 100/1000T | Yes Auto Disable Auto
    17 100/1000T | Yes Auto Disable Auto
    18 100/1000T | Yes Auto Disable Auto
    19 100/1000T | Yes Auto Disable Auto
    20 100/1000T | Yes Auto Disable Auto
    21 100/1000T | Yes Auto Disable Auto
    22 100/1000T | Yes Auto Disable Auto
    23 100/1000T | Yes Auto Disable Auto
    24 1000LX | Yes 1000FDx Disable 0
    Report Switch B
    transceivers
    24 | 1000LX | J4859C | DBLBHS0 | 1990-3657
    show time
    Thu Jul 4 02:31:42 2019
    Transceiver in 24
    Type : 1000LX
    Model : J4859C
    Connector Type : LC
    Wavelength : 1310nm
    Serial Number : DBLBHS0
    Status
    Temperature : 27.511C
    Voltage : 3.2800V
    Tx Bias : 15.500mA
    Tx Power : 0.0987mW, -10.056dBm
    Rx Power : 0.0594mW, -12.262dBm
    1 100/1000T | No Yes Up 1000FDx MDI off 0
    Port Settings
