Community Feedback
How is the community doing? Do you have any questions or feedback related for the Airheads Community team? This is the place to let us know.
Problems assigning dynamic network using CPPM
  • 1.  Problems assigning dynamic network using CPPM
    Posted Nov 29, 2023 02:32 PM
    I have an ssid with 802.1x active and it requests username and password, which must be the AD user
    Through the CPPM I establish that when a user connects, it validates which department they are in and, depending on the department, assigns a ROLE. In my Virtual controller, I have defined that it assigns a VLAN according to the ROLE.
    The problem is that I see that the CPPM does send the correct instruction but in the VC it ​​assigns me the default user.
    I share enforcement capture
    I share my Wi-Fi network configuration with 802.1x
  • 2.  RE: Problems assigning dynamic network using CPPM
    Posted Dec 05, 2023 12:04 PM
    Two things to have a look at:
    • Make sure that your ClearPass Service is not in Monitoring mode (should show a green dot), because in monitoring mode the attributes show up on Access Tracker but are not sent.
    • Remove the Role Assignment Rules. The Aruba-User-Role is automatically applied, like the Aruba-User-VLAN.
