Problems by restoring config file
  • 1.  Problems by restoring config file
    Posted Jun 13, 2016 10:24 AM
    Hi community,
    we have a problem by restoring the config file.
    We restored it, but we get an altert that the guest role does not exist:
    We installed the firewall license and all other profiles works fine.
    When I take a look to the config file the user-role configuration for this profile is not loaded by the controller:
    old Controller:
    new controller(no user-role for xx-Guest-guest-logon):
    I cannot add the profile via cli:3.PNG
    Have anyone an idea to fix this problem?
    Thanks.
    Regards
    Leon
  • 2.  RE: Problems by restoring config file
    Posted Jun 13, 2016 11:02 AM
    Add the guest-logon role via the CLI but do not add the first 2 access lists (global & apprf), they will be added automatically.
    Cheers
    James
  • 3.  RE: Problems by restoring config file
    Posted Jun 13, 2016 11:06 AM
    Can you write me what I have to do step by step?
  • 4.  RE: Problems by restoring config file
    Posted Jun 13, 2016 11:29 AM
    This will probably do the trick:
    user-role xxx-guest-guest-logon
    captive-portal xxx-Guest-cp_prof (change this to the exact spelling of your captive portal profile)
    access-list session logon-control
    access-list session captiveportal
    aaa profile xxx-guest-aaa_prof (change this to the exact spelling of your aaa profile)
    initial-role xxx-guest-guest-logon
    end
    Make sure your captive portal & aaa profile is there and you've got the spelling and capitalisation right when adding it.
    Cheers
    James
  • 5.  RE: Problems by restoring config file
    Posted Jun 13, 2016 11:59 AM
    You need to reboot after you install the PEF license. After you reboot, copy the config file to the controller and set that at the startup config, and then reboot
  • 6.  RE: Problems by restoring config file
    Posted Jun 13, 2016 12:50 PM
    Hi Cjoseph,
    ok, I uploaded the config and then installed the PEF license. :-)
    I test it yesterday to put on license first an than the config.
