Problems connecting WEMO Belkin Wifi light switch to AP 205
  • 1.  Problems connecting WEMO Belkin Wifi light switch to AP 205
    Posted Jan 29, 2015 12:40 PM
    I have a WEMO Belkin Light switch when I goto connect it to the AP it is coming up in the IDS as rogue and the device cannot connect to it, the security levels are set to the lowest point, any ideas?
  • 2.  RE: Problems connecting WEMO Belkin Wifi light switch to AP 205
    Posted Jan 29, 2015 12:43 PM
    If you are not enforcing rogues, then the issue lies between your device and the light switch as it uses a softAP connection model.
    Tim
  • 3.  RE: Problems connecting WEMO Belkin Wifi light switch to AP 205
    Posted Jul 08, 2015 10:49 AM
    I have a similar problem, in that WeMo won't work with Aruba (275/225 in my case). I created a 2.4-only SSID and ran through the configuration with that. I see it appear on Airwave as authenticated, but the unit itself blinks red on its wifi light and I cannot connect the client to it. I've tried factory reset any number of times.
    I'll take it home (where I have another one working) and see if maybe getting a firmware update will help here.
    Frustrating - I am in a zoo (literally) and have some IP cameras in an animal enclosure that need fairly frequent power cycling. WEMO would be perfect for this, as it can be a hassle to schedule access.
  • 4.  RE: Problems connecting WEMO Belkin Wifi light switch to AP 205
    Posted Jul 08, 2015 10:53 AM
    Do you see them in the AirGroup servers list?
  • 5.  RE: Problems connecting WEMO Belkin Wifi light switch to AP 205
    Posted Jul 08, 2015 11:03 AM
    Is that in AirWave? I'm not sure where to look for an Airgroup server list.
  • 6.  RE: Problems connecting WEMO Belkin Wifi light switch to AP 205
    Posted Jul 08, 2015 11:06 AM
    On the controller: show airgroup servers
  • 7.  RE: Problems connecting WEMO Belkin Wifi light switch to AP 205
    Posted Jul 08, 2015 11:10 AM
    Thanks. No, the Wemo is not in that list. I only have 3 listed, and they're all airprint services
  • 8.  RE: Problems connecting WEMO Belkin Wifi light switch to AP 205
    Posted Jul 08, 2015 11:13 AM
    Did you add a custom service for Wemo?
  • 9.  RE: Problems connecting WEMO Belkin Wifi light switch to AP 205
    Posted Jul 08, 2015 11:19 AM
    No custom service (I wouldn't even know how to do that).
    My first WEMO was at home, where I have a Cisco router that puts out separate 5 and 2.4 SSIDs. It was quite straightforward and was operational in 5 minutes.
    Trying at work, no joy. I had a few SSIDs which were all multiband. So I created a 2.4 only, just to see.
    That SSID is ZooStaff2.4 and something I read will have me try all lower case and no period (zoostaff24) and see if that works.
  • 10.  RE: Problems connecting WEMO Belkin Wifi light switch to AP 205
    Posted Jul 08, 2015 11:21 AM
    Wemo uses custom services that are not built-in to AirGroup. You need to
    create a custom AirGroup service with the appropriate service IDs.
    You can see the service IDs by running show airgroup blocked-service-id
  • 11.  RE: Problems connecting WEMO Belkin Wifi light switch to AP 205
    Posted Jul 08, 2015 11:26 AM
    First, thanks very much for working with me on this!
    Even though this doesn't match the IP that I am seeing in AirWave for the WEMO, here's the results that look likely on the blocked services command:
    10.170.138.149  urn:Belkin:device:controllee:1                  88
    10.170.138.149  urn:Belkin:service:WiFiSetup:1                  89
    10.170.138.149  urn:Belkin:service:timesync:1                   87
    10.170.138.149  urn:Belkin:service:basicevent:1                 87
    10.170.138.149  urn:Belkin:service:firmwareupdate:1             89
    10.170.138.149  urn:Belkin:service:rules:1                      89
    10.170.138.149  urn:Belkin:service:metainfo:1                   89
    10.170.138.149  urn:Belkin:service:remoteaccess:1               89
    Can you tell me how I might go about ublocking these services?
    Thanks!!
  • 12.  RE: Problems connecting WEMO Belkin Wifi light switch to AP 205
    Posted Jul 08, 2015 11:30 AM
    hmm, and now maybe I have an explanation for why I couldn't get a Foscam IP Camera to work on my outdoor AP's
  • 13.  RE: Problems connecting WEMO Belkin Wifi light switch to AP 205
    Posted Jul 08, 2015 11:39 AM
    Take a look at defining an AirGroup service:
    http://www.arubanetworks.com/techdocs/ArubaOS_64x_WebHelp/Web_Help_Index.htm
    #ArubaFrameStyles/AirGroup/Integrated_Deployment_Model.htm
  • 14.  RE: Problems connecting WEMO Belkin Wifi light switch to AP 205
    Posted Jul 10, 2015 10:07 AM
    Many thanks for the help.
    I needed to do a combination of things:
    • Belking services enabled in an Airgroup
    • simplify the SSID to lower case, no special characters
    • simplify the password on the SSID to lowercase, no special characters
    • Put the SSID on a 2.4 Ghz only radio
    • and the weirdest, use an older device (in my case an iPod) that doesn't have an AC radio
    Funny, the WEMO wifi light is still amber. But I can see it on my iPod and turn it off an on, which is all I wanted to do.
  • 15.  RE: Problems connecting WEMO Belkin Wifi light switch to AP 205
    Posted Dec 11, 2016 04:30 AM
    Very late response here but just be sure your WeMo light switch can ping the gateway address. If it cannot ping the gateway the amber light will flash and it will continue to broadcast a hidden open SSID, even though it may connect successfully to your network and work as expected.
  • 16.  RE: Problems connecting WEMO Belkin Wifi light switch to AP 205
    Posted May 03, 2018 11:40 PM
    This solved my problem
    2.4Ghz only
    Lower case letters only for BOTH SSID and Password.
    Thank you!
  • 17.  RE: Problems connecting WEMO Belkin Wifi light switch to AP 205
    Posted Mar 17, 2020 08:08 PM
    Hi!
    I had a problem with Wemo switches today and was able to get them to connect by disabling 802.11k.
