Problems with iphone ios9 and aruba IAP103
  • 1.  Problems with iphone ios9 and aruba IAP103
    Posted Dec 19, 2016 04:49 AM
    I have 3 aruba iap103's. I have 3 apple devices and 1 android device. With the iphone i cannot stream netflix to the chromecast. With the android i can.
    Youtube is no problem but with netflix i do not see the stream option on the iphone.
    Does anyone have a solution? I have installed the latest firmware that is available via update.
    Danny
  • 2.  RE: Problems with iphone ios9 and aruba IAP103
    Posted Dec 19, 2016 04:58 AM
    If you install the Chromecast app on the iPhone, can you setup the actual Chromecast?  What's the version of Netflix on the iPhone?
  • 3.  RE: Problems with iphone ios9 and aruba IAP103
    Posted Dec 19, 2016 05:11 AM
    Hi yes i can install the chromecast. netflix is version 9.0.3(871) 4.3.4-360
    Youtube streaming is working fine.
    danny
  • 4.  RE: Problems with iphone ios9 and aruba IAP103
    Posted Dec 19, 2016 05:33 AM
    Do you even see the Chromecast icon on the Netflix app?
  • 5.  RE: Problems with iphone ios9 and aruba IAP103
    Posted Dec 19, 2016 05:51 AM
    No i do not see that in netflix
  • 6.  RE: Problems with iphone ios9 and aruba IAP103
    Posted Dec 19, 2016 06:04 AM
    Is "Guest" mode enabled on your Chromecast?  If not, then enable it, wait a few seconds and you'll probably see the Chromecast icon appear in the Netflix application.
  • 7.  RE: Problems with iphone ios9 and aruba IAP103
    Posted Dec 19, 2016 07:15 AM
    Ok i will try this. Will let you know if this was the solution.
  • 8.  RE: Problems with iphone ios9 and aruba IAP103
    Posted Dec 19, 2016 09:47 AM
    I can see the sign now but it cannot connect.
    Danny
  • 9.  RE: Problems with iphone ios9 and aruba IAP103
    Posted Dec 19, 2016 10:11 AM
    That's because in guest mode, you are connecting adhoc to the Chromecast.  In your Chromecast setup, in the Guest Mode dialogue, you'll see you have different PIN than your "normal" Chromecast mode.
    Don't forget that in Guest Mode, any device in with connectivity to the Chromecast can connect adhoc if they know the Guest PIN.
    From the Aruba IAP side, I assume your iPhones are in the the same SSID and VLAN as the Chromecast and you have enabled airgroup services, correct?
  • 10.  RE: Problems with iphone ios9 and aruba IAP103
    Posted Dec 21, 2016 07:22 PM
    If you haven't done so already, make sure you check all the DLNA protocols in airgroup.
