Problems with Radius authentication - WLC
  • 1.  Problems with Radius authentication - WLC
    Posted May 25, 2016 01:26 PM
    I have a WLC and I have a SSID with Radius Authentication, it was working but after a while it stops working:
    I did a tracebuf:
    (PA-TB-WCONTROLLER01) #show auth-tracebuf mac 94:65:9c:45...
    (PA-TB-WCONTROLLER01) #show auth-tracebuf mac 94:65:9c:45:7a:31
    Auth Trace Buffer
    May 25 07:13:23  station-up             *  94:65:9c:45:7a:31  40:e3:d6:51:77:90  -  -  wpa2 aes
    May 25 07:13:23  eap-id-req            <-  94:65:9c:45:7a:31  40:e3:d6:51:77:90  1  5
    May 25 07:13:26  station-down           *  94:65:9c:45:7a:31  40:e3:d6:51:77:90  -  -
    May 25 07:18:16  station-up             *  94:65:9c:45:7a:31  40:e3:d6:51:77:90  -  -  wpa2 aes
    May 25 07:18:16  eap-id-req            <-  94:65:9c:45:7a:31  40:e3:d6:51:77:90  1  5
    May 25 07:18:19  station-down           *  94:65:9c:45:7a:31  40:e3:d6:51:77:90  -  -
    May 25 07:18:36  station-up             *  94:65:9c:45:7a:31  40:e3:d6:51:77:90  -  -  wpa2 aes
    May 25 07:18:36  eap-id-req            <-  94:65:9c:45:7a:31  40:e3:d6:51:77:90  1  5
    May 25 07:18:39  station-down           *  94:65:9c:45:7a:31  40:e3:d6:51:77:90  -  -
  • 2.  RE: Problems with Radius authentication - WLC
    Posted May 25, 2016 01:31 PM
    Was that client previously successful at authentication?
    What is providing the radius service? Can you check to see if the requests are hitting the server?
  • 3.  RE: Problems with Radius authentication - WLC
    Posted May 25, 2016 01:34 PM
    Yes, we had no problems before, what additional test can i perform?
    is a NPS server, I'll try to get access to that.
  • 4.  RE: Problems with Radius authentication - WLC
    Posted May 25, 2016 01:41 PM
    Test using the controller aaa test server
    Make sure your certificate hasn't expired ?
    Have you guys made any changes on the RADIUS server shared key or the NAS IP address on the controller?
  • 5.  RE: Problems with Radius authentication - WLC
    Posted May 25, 2016 07:08 PM
    Test with aaa test-server is successful but when trying from computer is failing.
  • 6.  RE: Problems with Radius authentication - WLC
    Posted May 25, 2016 07:18 PM
    The client seems to be failing when the AP/Controller asks for an EAP-ID request.  What client is this and how is the client configured for 802.1x?
