Problems with RAP deployment
  • 1.  Problems with RAP deployment
    Posted May 22, 2015 06:07 AM
    Hi community,
    I´ve problems to deploy my rap3. we ´ve a 7030 controller with code6.4 running.
    APs works fine.
    The RAP woks fine when I put it into a local ethernet port in our companys lan.
    but when I put my 3g Sitck in it the rap comes up and i can see it for short time on my controller it says:
    Flag Rc2D and I cannot see it into the controller gui. The 3g stick works fine, I can ping 8.8.8.8 from the rap and I can ping the external ip of the controller...
    What is the problem?
  • 2.  RE: Problems with RAP deployment
    Posted May 22, 2015 06:14 AM
    You should first see if it will work on a wired port on the public internet.  That will rule out an issue with your 3G stick.
    #! resolution to this issue:  If the ap-group that the AP is in has a system profile that has an lms-ip in it, remove the LMS-ip.
  • 3.  RE: Problems with RAP deployment
    Posted May 22, 2015 06:27 AM
    Thanks, what a fast anwer.... :-)
    shame on me, it was the lms promlem
