Problems with the splash screen
  • 1.  Problems with the splash screen
    Posted Jan 24, 2020 01:02 PM
    I have an Aruba 207 accespoint on which i have implemented a splash screen for the guest network. If the users connect to the accespoint and the splash screen pops-up to enter the guest credentials, the browser gives a warning that the page is not secure and you must accept the risk and continue.
    I don't want this unsecured page/ warning to show up and that the users can connect normally without clicking on "accept risk and continue".
    Can you guys help me out of this?
    Also, is there any way that i change this pop-up page from HTTPS to HTTP?
  • 2.  RE: Problems with the splash screen
    MVP
    Posted Jan 24, 2020 01:30 PM
    You can use HTTP only if you are using an External Captive Portal, in the case if you are using InstantAP. Otherwise, you need to have a Signed Certificate from a Trusted CA.
  • 3.  RE: Problems with the splash screen
    Posted Jan 24, 2020 01:38 PM
    Can i get more info how i can create or get a Signed Certificate from a Trusted CA?
  • 4.  RE: Problems with the splash screen
    MVP
    Posted Jan 24, 2020 01:43 PM
