1)do the errors follow cabling? Change the cabling of the 4ports in order to be sure that the problem is switch-based when the errors remain on the 4ports.
2)Check switch internal eventlogs
3)Are there specific switch settings on these ports like mac-security or stp?
3)Check Switch Firmware for newer version
hth
robert
