Hi.
One of our offices have been plagued by a hard to find issue for a while now, and i suspect the issue to be with the network switch at some level, even though we replaced the switch, and the same issue prevails.
The office is set up with pretty much the same equipment as all our other offices.
Equipment: 2620 PPOE+ (J9624A) (previously 15.17 firmware, now 16.02..14. same issue on both versions)
Issue facts:
Some ARP entries disappear from the arp table. This does not happen to the other offices we have the same switches in. Items that can disappear from the ARP table is a ESXi server and an Access Point.
I then have to ping those items from the switch before i can access them from a remote location
they are set up properly with gateway settings and such.
Equipment that are connected through HP unmanaged 8/16 port switches will loose network access (we tried replaing all table switches with new ones with no luck). If i replace one of those table switches with a default config 2620, and connect the equipment to it directly, the equipment stays connected with no issue.
When they loose network access, it seems they only loose access to external addresses, while internal devices are still reachable(ISP has checked their side, and found no issue. even replaced their modem just to be sure)
Even though some equipment looses access to stuff that is external to the 2620 main switch, other equipment will at the same time work. and its not the same equipment each time. it appears to be random.
I have tried activating spaning-tree and loop-protect, but no loops are detected.
The configuration is pretty basic. i have tried debug syslogging, but that does not really give me anything understandable. Here is the show config
; J9624A Configuration Editor; Created on release #RA.16.02.0014
; Ver #0e:01.10.82.34.41.1c.28.f3.84.9c.63.ff.37.2f:b3
hostname "Drammen-Hoved2620"
mirror-port 13
fault-finder broadcast-storm sensitivity high
fault-finder bad-driver sensitivity high
fault-finder bad-transceiver sensitivity high
fault-finder bad-cable sensitivity high
fault-finder too-long-cable sensitivity high
fault-finder over-bandwidth sensitivity high
fault-finder loss-of-link sensitivity high
fault-finder duplex-mismatch-hdx sensitivity high
fault-finder duplex-mismatch-fdx sensitivity high
fault-finder link-flap sensitivity high
logging 172.20.0.80
max-vlans 50
timesync sntp
sntp unicast
sntp server priority 1 172.20.0.37
time daylight-time-rule western-europe
time timezone 60
ip route 0.0.0.0 0.0.0.0 192.168.254.77
ip routing
snmp-server community "public" unrestricted
snmp-server enable traps mac-notify
snmp-server enable traps mac-count-notify
vlan 1
name "DEFAULT_VLAN"
no untagged 1-26
untagged 27-28
no ip address
exit
vlan 1040
name "Powertech"
untagged 1
ip address 192.168.254.78 255.255.255.252
exit
vlan 1041
name "Ansatt"
untagged 2-8,25
tagged 26
ip address 10.130.152.1 255.255.255.0
exit
vlan 1042
name "Gjest"
tagged 26
ip address 10.130.153.1 255.255.255.0
ip helper-address 10.130.152.10
exit
vlan 1043
name "Tynnklient"
untagged 9-24
tagged 26
ip address 10.130.154.1 255.255.254.0
exit
no tftp server
loop-protect 2-24
loop-protect trap loop-detected
loop-protect disable-timer 600
no dhcp config-file-update
no dhcp image-file-update
device-profile name "default-ap-profile"
cos 0
exit
Any help on this would be much appreciated :)
#ARP#2620
