Hi guys,
So I am completley new to Vlan and diving in at the deep end here.
I want to setup 2 Vlans on my 2626
At the moment I am going to leave the deafult vlan as my first and add in the second which will be for BYOD network.
For testing I will be using only the 1 switch (2626)
Port 1 conected to the Windows 2003 DHCP server
Port 2 connected to BYOD device (laptop)
Port 3 Desktop PC
Currently I have 2 scopes set up on server
20.192.202.0
168.192.0.0
I want devices in port 2 to obtain a 168.192 address and all other ports a 20.192 address.
So far on the switch I have -
Enabled Routing
Enabled DHCP relay
set manual IP for both vlans
on default ports 1 & 3-24 untagged
on Vlan 20 port 2 untagged
I think I am going very wrong somewhere as this is simply not working and have tried a variety of things which has not worked. Any help would be very much appreciated.
P.S. This thread has been moved from Switches, Hubs, Modems (Legacy ITRC forum) to ProCurve / ProVision-Based. -HP Forum Moderator
#VLAN#2626#DHCP#ProCurve#Networking
