hi
I need to acess procurve switch 2650-24p throu web. please let me know the procedure.
Is there any default ip address
Is it possbile to create ip for managment vlan and can access thoru web portal
please let me know the solution
Regards
Biju
The default config of 26xx switches is to receive a DHCP address in VLAN1. So have a look in your DHCP server and check what address the switch has received. If it is not connected to the network yet then you need to connect to the console port with a cable and use some kind of terminal program like PuTTY.
