Comware
  • 1.  Procurve 2910al-24 fiber Stacking
    Posted Jun 12, 2012 11:29 AM
    Hi All,
    I'm currently setting up a distribution network for my company. I have two 2910 which will be installed on 2 different floors.
    I've add two X121 Gbic for the connection between the 2 switches.
    In the lab : 2 switch connected with a LC-LC fiber (62um) - Forced the Gbic port from Auto to 1000FDx and they come up.
    Everything is tested and OK.
    My issue :
    When the switches are installed in the rack on different floors, connected to the building fiber network with fiber cords => Gbic ports are not coming up...
    I've changed the fiber cords, cross the plugs... Nothing happens
    My Questions :
    - Is X121 Gbi the rigth choice and may be an issue ?
    - I'm using OM1 fiber cord (62,5um) but not sure about the fiber type of the building . Could be a cause ?
    - Do you see any other point I can check/change ?
    Thanks in advance for your help.
    Christophe
    #GBIC
    #X121
    #fiber
  • 2.  RE: Procurve 2910al-24 fiber Stacking
    Posted Jun 13, 2012 07:48 AM
    Hi
    Since it works in the lab, I'd say get someone onsite to check the building fiber type and measure if it's actually working.
  • 3.  RE: Procurve 2910al-24 fiber Stacking
    Posted Jun 13, 2012 11:56 AM
    Thanks for the reply.
    That's what I've done today and it seems that the fiber in the building is a OS1 9/125um single mode.(What I can find from the reference printed on it); and my GBIC are SFP LC SX HP X121(J4858C) which are only multimode.
    I think (and correct me if I'm wrong) that if I change the Gbic to the J4859C model it should work.
    Christophe
