Wired Intelligent Edge
  • 1.  Procurve 2910al MSTP to Cisco SG500 MSTP not playing fair
    Posted Jan 04, 2014 07:16 PM
    Hello.  I am encountering a really hair-tearing issue here.  I have a stack of HP 2910al running MSTP and a stack of Cisco SG500X units running MSTP.
    I have identically configured instances and can show that the base spanning-tree process is recognizing that there is some topology change when i change the switch priority.  The can trade off who is the CST Root.  I am, however, unable to get the instance on the HP switch to recognize who is root.
    I cannot pass traffic on any vlan, (except for native VL1).
    Here we can see the HP 2910 switch recognizes the cisco switch as being the root (the basic spanning tree sees the designated bridge):
    HP-SW-1(config)# sh spanning-tree
     Multiple Spanning Tree (MST) Information
      STP Enabled   : Yes
      Force Version : MSTP-operation
      IST Mapped VLANs : 2-9,11-19,21-29,31-99,101-109,111-799,801-4094
      Switch MAC Address : 38eaa7-75a780
      Switch Priority    : 8192
      Max Age  : 20
      Max Hops : 20
      Forward Delay : 15
      Topology Change Count  : 5
      Time Since Last Change : 5 mins
      CST Root MAC Address : d4d748-ccac1a  < - The Cisco 500
      CST Root Priority    : 4096
      CST Root Path Cost   : 60000
      CST Root Port        : 1
      IST Regional Root MAC Address : 38eaa7-75a780  < -  MY HP 2910
      IST Regional Root Priority    : 8192
      IST Regional Root Path Cost   : 0
      IST Remaining Hops            : 20
      Root Guard Ports     :
      TCN Guard Ports      :
      BPDU Protected Ports :
      BPDU Filtered Ports  :
      PVST Protected Ports :
      PVST Filtered Ports  :
                      |           Prio            | Designated    Hello
      Port  Type      | Cost      rity State      | Bridge        Time PtP Edge
      1     100/1000T | 20000     64   Forwarding | 00147c-488b40 2    Yes No
    BUT HERE, the HP switch sees itself to be the root bridge for the instance #1 – and the designated bridge is the HP2910 itself…
    MP-SW-1(config)# sh spanning-tree instance 1
     MST Instance Information
      Instance ID : 1
      Mapped VLANs : 1,10,20,30,100,110,800
      Time Since Last Change  : 9 mins
      Regional Root Port        : This switch is root
      Remaining Hops            : 20
        Designated
      Port  Type      Cost      Priority Role       State        Bridge
      1     100/1000T 20000     128      Master     Forwarding   38eaa7-75a780
    Here’s my HP configuration (with fluff removed):
    interface 1
       name "Cisco Stack"
       no power-over-ethernet
       exit
    vlan 10
       name "Management"
       tagged 1,Trk1-Trk2    < - NOTE: Vlan’s are all tagged on VL1
       ip address 172.16.10.1 255.255.255.0
       exit
    spanning-tree
    spanning-tree 1 priority 4
    spanning-tree Trk1 priority 4
    spanning-tree Trk2 priority 4
    spanning-tree config-name "Irvine"
    spanning-tree config-revision 1
    spanning-tree instance 1 vlan 1 10 20 30 100 110 800
    spanning-tree instance 1 Trk1 priority 4
    spanning-tree instance 1 Trk2 priority 4
    spanning-tree priority 2
    The Cisco SX500 is not as robust of a CLI set as the commercial 3560’s etc.  But here’s the way this unit looks:
    spanning-tree mode mst
    spanning-tree priority 4096
    spanning-tree mst configuration
    instance 1 vlan 1,10,20,30,100,110,800
    name Irvine
    revision 1
    exit
    spanning-tree mst 1 priority 4096
    vlan database
    vlan 10,20,30,100,110,800
    interface gigabitethernet1/1/1
     description "To other Core"
     spanning-tree link-type point-to-point
     spanning-tree mst 1 cost 20000
     switchport trunk allowed vlan add 10,20,30,100,110,800
    #cisco
    #Spanningtree
    #MSTP
  • 2.  RE: Procurve 2910al MSTP to Cisco SG500 MSTP not playing fair
    Posted Jan 05, 2014 03:50 AM
    I would guess this has to do with VLAN 1 not beeing allowed on the SG500 trunk. Also you might still have a problem if VLAN1 is tagged from the HP but untagged (native per default) on the SG500.
  • 3.  RE: Procurve 2910al MSTP to Cisco SG500 MSTP not playing fair
    Posted Jan 05, 2014 02:01 PM
    I'd agree that there would be a problem if VL1 was blocked - but it is the only VLAN that is passing.  I have VL10 set up as my management VLAN and have the appropriate L3 SVI's on each side.  Should work.
    I'm looking for any hints and tidbits!
  • 4.  RE: Procurve 2910al MSTP to Cisco SG500 MSTP not playing fair
    Posted Jan 05, 2014 02:02 PM
    BTW - VL1 is untagged (native) on both sides.
  • 5.  RE: Procurve 2910al MSTP to Cisco SG500 MSTP not playing fair
    Posted Jan 05, 2014 03:22 PM
    According to your config, gigabitethernet1/1/1 on the Cisco is not allowing VLAN1. Doesn't matter if its the native VLAN, if its no inte allowed list it wont be used.
  • 6.  RE: Procurve 2910al MSTP to Cisco SG500 MSTP not playing fair
    Posted Jan 10, 2014 03:07 AM
    Oh yes it is permitted. VL1 is a very special VL. By default it is the native VL and will be passed. In this case, if VL1 was NOT passed, I would have NO access to the Cisco switch as it is cross-connected to the HP switch and that is how I have my management access.
  • 7.  RE: Procurve 2910al MSTP to Cisco SG500 MSTP not playing fair
    Posted Jan 06, 2014 05:38 AM
    I would check the MSTP configuration digests on both switches, if you are seeing multiple regional roots.
  • 8.  RE: Procurve 2910al MSTP to Cisco SG500 MSTP not playing fair
    Posted Jan 06, 2014 07:26 AM
    Agreed - start with checking that the MSTP Digests match:
    Cisco : show spanning-tree mst digest
    HP : show spanning-tree mst-config
    Pete
  • 9.  RE: Procurve 2910al MSTP to Cisco SG500 MSTP not playing fair
    Posted Jan 10, 2014 03:05 AM
    Hi guys - - thanks for the advice.  The syntax for the show spanning-tree mst digest does not really exist on the SG500X switch.  HOWEVER, with this comment, I did observe that the HP switch shows a RATHER LONG 0xNNNNNNNNNNNNNNN digest key.  The Cisco does NOT.
    Any other suggestions?
    Oh, the advertised or permitted VLANS are identical and the revision is identical and the domain name is identical.
  • 10.  RE: Procurve 2910al MSTP to Cisco SG500 MSTP not playing fair
    Posted Jan 10, 2014 03:08 AM
    Here is the cisco equivalent to the suggested digest command:
    switchccac1a#sh spanning-tree mst-configuration
    Gathering information ..........
    Current MST configuration
    Revision: 1
    Instance  Vlans Mapped                                       State
    1         1,10,20,30,100,110,800                             enabled
    switchccac1a#
    For the HP, this is what I see:
    IRV_SHORETEL-0(config)# sh spanning-tree mst-config
     MST Configuration Identifier Information
      MST Configuration Name : Irvine                            MST Configuration Revision : 1      MST Configuration Digest : 0x4211DA627F7479E5EDD3B93099652B67
      Instance ID Mapped VLANs                                               ----------- ---------------------------------------------------------   1           1,10,20,30,100,110,800
