Product/AOS matrix
  • 1.  Product/AOS matrix
    Posted Feb 01, 2012 02:05 PM
    Is there a quick and easy way to compare functionality between AOS versions?
    For instance, if you were trying to build a case for upgrading from 5.x.x to 6.x.x what is the easiest way to find out what the differences are between the releases?
  • 2.  RE: Product/AOS matrix
    Posted Feb 01, 2012 05:10 PM
    I think a good amount on info on the changes and improvements can be found in the release notes for the first code versions of 6.0.x.x and 6.1.x.x. I have never seen a matrix for this. Of the top of my head some features that I believe were added at some point in AOS 6 were a management dashboard, device type classification, dns named acl's and other.
    The compatiblity matrix for AP's can make a case that some newer AP's are not supported on 5.x.x.x. See link below:
    http://www.arubanetworks.com/pdf/products/MAT_AP.pdf
