Proper L2TPv3 VPN Controller Configuration to Support IAP Tunnel
  • 1.  Proper L2TPv3 VPN Controller Configuration to Support IAP Tunnel
    Posted Feb 12, 2018 01:00 PM
    Greetings,
    I am looking for some information on how to properly set up the subject configuration between a 3200 controller and a iap225, I also have tried a rap3 with no success as well. I have performed multiple searches but yet to find a complete explanation of the required configuration for both the controller and the iap ends of the connection. The main issue that I am having is where to configure the iap's l2tpv3 psk on the controller side. I added the iap mac to the whitelist, created the required pool, and from what I have read that's pretty much it. I have tried to bring up the tunnel but not seeing the controller responding. I am also not finding much help with commands to use to troubleshoot the l2tp vpn issue on the controller either.
    Controller info:
     #show version
    ArubaOS (MODEL: Aruba3200-US), Version 6.4.3.9
    Website: http://www.arubanetworks.com
    Copyright (c) 2002-2016, Aruba Networks, Inc.
    Compiled on 2016-05-27 at 14:02:53 PDT (build 55230) by p4build
    Any help or feedback would be greatly appreciated.
    Thanks in advance,
    Jaime
