Wired Intelligent Edge
Protocol for Ring Network
  • 1.  Protocol for Ring Network
    Posted Sep 18, 2020 04:54 AM
    There are HPE FF 5940 switches used in the Ring Network.  Attached the logical diagram.  Wondering which would be the best protocol to configure for this network.  RRPP?
  • 2.  RE: Protocol for Ring Network
    Posted Sep 19, 2020 04:12 AM
    5940s support Ethernet Ring Protection Switching (ERPS).
    https://support.hpe.com/hpesc/public/docDisplay?docId=a00041110en_us
  • 3.  RE: Protocol for Ring Network
    Posted Sep 20, 2020 11:28 PM
    Thanks for the info Ariyap.
    By the way, is ERPS more recommended comparing to RRPP or other protocols?
  • 4.  RE: Protocol for Ring Network
    Posted Sep 21, 2020 08:50 AM
    it all depends on what you are trying to achieve, as such there is no recommendation. ERPS is an ITU standard and hence if you need interoperability, then that would be my choice.
