Provision button broken
  • 1.  Provision button broken
    Posted Jul 23, 2013 11:35 AM
    I recently upgraded to 6.2.1.2 on a Aruba 3600 and now it looks like provisioning is broken in the webpage.  I select the newly discovered AP and click on the provision button and nothing happens.  I can't even reprovision existing APs.  Has anybody else had this problem?  I'm looking through the config to see if I can do this in SSH.
    #3600
  • 2.  RE: Provision button broken
    Posted Jul 23, 2013 11:36 AM
    Have you tried using another BROWSER ?
    I currently have 6.2.1.2 installed and I'm not experiencing that issue
  • 3.  RE: Provision button broken
    Posted Jul 23, 2013 11:37 AM
    If you clear the cache on your browser (or use a different browser), does it start working? You can provision APs from the CLI, but its a little more complicated than using the GUI.
  • 4.  RE: Provision button broken
    Posted Jul 23, 2013 11:40 AM
    Make sure you are using the following supported browsers:
  • 5.  RE: Provision button broken
    Posted Jul 23, 2013 12:02 PM
    Thank you.  The browser version was my problem.   I'm using Windows 8 with IE 10 and Firefox 22.  I used the developer tools in IE to set Browser Mode to IE 9 and the provisioning works.
  • 6.  RE: Provision button broken
    Posted Jul 23, 2013 01:30 PM
    Good to know
