Provisioning i-series gotcha
  • 1.  Provisioning i-series gotcha
    Posted Apr 22, 2013 05:36 AM
    If I order a "93" from Dell, I receive a i-93. Dunno if you can still get the classic 93's ?
    No biggy, you just convert it to a "controlled AP" in the webgui.
    The gotcha is that if you reset it to factory defaults using the purge/setenv master x.x.x.x/save/boot incantation, you revert it to an i-series AP.
    Then the AP won't show up in your provisioning table, although it receives an ip address in the same range as your controller (in a campus context), and you can ping it, so it can't be routing or vlan.
    At the end of its boot sequence the AP ominously states " I'm master now ". That gave it away ...
    In addition a ssid is created called "Instant".
    Wanted to share this, just in case.
    Ward
  • 2.  RE: Provisioning i-series gotcha
    Posted Apr 22, 2013 06:18 AM
    They need to send you the right part.  It is available.
