Provisioning Profile - Master IP/FQDN - [set/clear] - what's the difference?
  • 1.  Provisioning Profile - Master IP/FQDN - [set/clear] - what's the difference?
    Posted Jun 05, 2012 04:25 AM
    using here ArubaOS 6.1.3.2. Under Configuration -> Wireless ->AP Installation->Provisioning Profiles there are two options to define the Master IP/FQDN, set and clear. I searched for in User Guide but there it isn'nt mentioned.
    Can me anybody explain here please whats the different effects?
    I just want to set the FQDN of the master switch (different AP Groups with different provisioning profiles)
    Thanks in advance,
    Kokel
  • 2.  RE: Provisioning Profile - Master IP/FQDN - [set/clear] - what's the difference?
    Posted Jun 05, 2012 09:31 AM
    AFAIK, to put a master IP in a provisioning profile, use set.  If you want to remove a master IP from the profile, use clear.  I think in some older versions, it defaulted to "clear," which was a mess.
    However, if all you want to use a provisioning profile for is to set what the master is, you don't need a provisioning profile.  Just set the LMS in the AP System Group.
