Provisioning RAP5-WN as Remote AP doesnt work
  • 1.  Provisioning RAP5-WN as Remote AP doesnt work
    Posted Aug 23, 2012 05:15 AM
    When I provision a RAP5WN to act as a RAP it doesn't come back online anymore.
    I am using the webinterface and choose:
    Remote AP -> yes
    Remote AP authentiocation method -> Certificate
    This used to work.. what could cause this to fail?
  • 2.  RE: Provisioning RAP5-WN as Remote AP doesnt work
    Posted Aug 23, 2012 06:13 AM
    The #1 reason is that you have a private LMS-IP in the AP system profile of your AP-Group.  Remove it.
  • 3.  RE: Provisioning RAP5-WN as Remote AP doesnt work
    Posted Nov 27, 2012 07:32 AM
    I run into the same problem again.
    The ap group has  a different lms-ip indeed, because I want that RAP to connect to a specific controller. How will removing the lms-ip solve this?
  • 4.  RE: Provisioning RAP5-WN as Remote AP doesnt work
    Posted Nov 27, 2012 07:42 AM
    Because the RAP connects to a controller only when the LMS-IP address is PUBLIC, not private.  If it is public, it should work.  if it is a private address, it will not.
  • 5.  RE: Provisioning RAP5-WN as Remote AP doesnt work
    Posted Nov 27, 2012 07:47 AM
    I see! This use to work right? I have a few RAPs implemted this way.
    Is there a workaround for this? We use RAPs on our local network to get certain VLANs to our offshore production facilities safely.
  • 6.  RE: Provisioning RAP5-WN as Remote AP doesnt work
    Posted Nov 27, 2012 07:53 AM
    It does not work, unless your RAP is inside the firewall.  If your RAP is on the public internet, the LMS-IP needs to be a public ip address otherwise it will not work, period.  Or you can leave it blank.
    What are you trying to accomplish?
  • 7.  RE: Provisioning RAP5-WN as Remote AP doesnt work
    Posted Nov 27, 2012 07:56 AM
    We use RAPs on our platforms to deliver a sort of internet service to our employees that work offshore.
    Network wise the RAPs are on our LAN, inside our firewall.
    Im trying to get these RAPs to a certain controller, but everytime I try to provision a resetted RAP it won't come back up somehow.
  • 8.  RE: Provisioning RAP5-WN as Remote AP doesnt work
    Posted Nov 27, 2012 08:00 AM
    If it is inside the firewall it should work.  You should also make sure that both controllers are on the same version of code, otherwise you will have an upgrade/downgrade loop.
  • 9.  RE: Provisioning RAP5-WN as Remote AP doesnt work
    Posted Nov 27, 2012 08:02 AM
    They are both on version 6.1.3.1 so that can't be the issue.
  • 10.  RE: Provisioning RAP5-WN as Remote AP doesnt work
    Posted Nov 27, 2012 08:08 AM
    Please open a support case.
    The amount of troubleshooting and analysis needed to get to the bottom of this might be painful on this forum.  TAC is better equipped to resolve this more quickly.
  • 11.  RE: Provisioning RAP5-WN as Remote AP doesnt work
    Posted Nov 27, 2012 08:25 AM
    Will do. Thanks for the effort though!
  • 12.  RE: Provisioning RAP5-WN as Remote AP doesnt work
    Posted Aug 28, 2012 01:00 PM
    May be vpn pool is missing?
    can you copy paste output of "show log security 200" when your RAP fails to come-up?
    Is it a master-local scenario? They you need to ensure master is reachable, because by default local uses master for autheticating
    RAPs.
