Network Management
prtg setup
This thread has been viewed 21 times
  • 1.  prtg setup
    Posted Feb 13, 2017 10:49 AM
    Attempting to setup in PRTG ,
    tips or tricks appreciated. I saw in other forums that 1.3.6.1.4.1.14823.2.2.1.5.2.1.4 can be used to pull the names of access points. I an run that in paessler snmp tester, but pulls 90 lines of info , i only have 14 access points.
    not sure where to proceed from there.
  • 2.  RE: prtg setup
    Posted Feb 13, 2017 10:51 AM
    Use the PRTG MIB importer tool to import the Aruba private MIBs.
  • 3.  RE: prtg setup
    Posted Feb 13, 2017 11:13 AM
    Thank You, I didn't even know that existing.
    I'm workign on registering as a customer, as per the Mibs document to download the current mibs found here: https://community.arubanetworks.com/aruba/attachments/aruba/unified-wired-wireless-access/7568/1/ArubaOS_5%200MG.pdf
    Hopefully it all goes well. :)
  • 4.  RE: prtg setup
    Posted Feb 13, 2017 12:00 PM
    You will find more updated MIB documentation o the support page:
    https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Default.aspx?EntryId=21094
    As example for a ArubaOS Version 6.4.x
    Cheers
    Stefan
