PSK Auth Log
  • 1.  PSK Auth Log
    Posted Jan 24, 2022 11:08 PM
    Hi.
    I was wondering if there is any kind of log for PSK auth? In particular, I want to see successful and failed auth attempts, and if failed, any reason.
    I currently use show ap debug mgmt-frames for 802.1X and I'm looking for a PSK equivalent.
    Do Aruba IAPs have such a feature?
  • 2.  RE: PSK Auth Log
    Posted Jan 25, 2022 12:01 AM
    perhaps this could help you.
    show ap debug auth-trace-buf
  • 3.  RE: PSK Auth Log
    Posted Jan 26, 2022 10:28 PM
    Hi.
    Yes, that is sort of helpful but it only includes a few minutes and the info is pretty limited.
  • 4.  RE: PSK Auth Log
    Posted Jan 26, 2022 11:03 PM
    for PSK based Auth, generally it should show mic failure which means that the PSK is not correct.
