Ptk Challenge Failed (seq num 0)
  • 1.  Ptk Challenge Failed (seq num 0)
    MVP GURU
    Posted Nov 27, 2015 06:59 AM
    With a device, i get the following warning and the device will be longer to connect and get a IP Address
    show ap debug mgmt-frames
    Traced 802.11 Management Frames
    Timestamp        stype       SA                 DA                 BSS                signal  Misc
    16:32:32  deauth      94:b4:00:XX:XX:X2  4c:ed:de:XX:XX:X1  94:b4:00:XX:XX:X2  15      Denied; Ageout (seq num 0)
    16:32:13  assoc-resp  94:b4:00:XX:XX:X2  4c:ed:de:XX:XX:X1  94:b4:00:XX:XX:X2  15      Success
    16:32:13  assoc-req   4c:ed:de:XX:XX:X1  94:b4:00:XX:XX:X2  94:b4:00:XX:XX:X2  1
    16:33:48  assoc-resp  94:b4:00:XX:XX:X2  00:10:c6:XX:XX:X3  94:b4:00:XX:XX:X2  15      Success
    16:33:48  assoc-req   00:10:c6:XX:XX:X3  94:b4:00:XX:XX:X2  94:b4:00:XX:XX:X2  1       -
    16:33:48  auth        94:b4:00:XX:XX:X2  00:10:c6:XX:XX:X3  94:b4:00:XX:XX:X2  15      Success (seq num 0)
    16:33:48  auth        00:10:c6:XX:XX:X3  94:b4:00:XX:XX:X2  94:b4:00:XX:XX:X2  0       -
    16:33:47  deauth      94:b4:00:XX:XX:X2  00:10:c6:XX:XX:X3  94:b4:00:XX:XX:X2  15      Ptk Challenge Failed (seq num 0)
    Any idea ?
  • 2.  RE: Ptk Challenge Failed (seq num 0)
    Posted Nov 27, 2015 07:16 AM
    What version of ArubaOS?
    What kind of client device is this?
    What kind of encryption are you using?
  • 3.  RE: Ptk Challenge Failed (seq num 0)
    MVP GURU
    Posted Nov 27, 2015 02:35 PM
     Last GA IAP release
     Scan
     Mixted mode (WPA-PSK and WPA2-PSK)
  • 4.  RE: Ptk Challenge Failed (seq num 0)
    Posted Nov 27, 2015 03:05 PM
    This message is something that occurs:
    - When there is a certain level of interference
    - When the driver on a device is not up to date
    It could be either of the two or a combination of the two reasons.
    I would also say to limit your SSID only to a single type of encryption, not two.
  • 5.  RE: Ptk Challenge Failed (seq num 0)
    MVP GURU
    Posted Nov 27, 2015 03:22 PM
    How to known about interference ?
    Yes i known about encryption and SSID but i have some old scan don't support AES... (WPA2-PSK)
