Quick Public Cert question:
A customer will be load balancing between clearpass nodes per region. Each region will be doing zone based DNS for resolution of the address.
If all redirects were pointed to the clearpass.customer.com and not referencing the local host name at all, is there a need to have local server names in the SAN field, or can the same public cert be put on each of the servers without any SANs (or sans SANs if you will! )
Thanks!
