publisher virtual IP on different subnet with physical IP
  • 1.  publisher virtual IP on different subnet with physical IP
    Posted Mar 12, 2018 08:09 AM
    Hi aruba master
    based on the clustering technotes, we can configure the publisher on separate subnet.
    can we configure vip fir this case?
    thanks
  • 2.  RE: publisher virtual IP on different subnet with physical IP
    Posted Mar 12, 2018 08:29 AM
    The virtual IP needs to be in the same subnet. Why are you using public IPs?
  • 3.  RE: publisher virtual IP on different subnet with physical IP
    Posted Mar 12, 2018 08:55 AM
    Hi tim
    So for publisher with l3 separated, we can not configure virtual ip? What is the ha scheme in vip ?
  • 4.  RE: publisher virtual IP on different subnet with physical IP
    Posted Mar 12, 2018 09:00 AM
    The virtual IP requires L2 connectivity. It’s CARP.
  • 5.  RE: publisher virtual IP on different subnet with physical IP
    Posted Mar 12, 2018 09:07 AM
    Correct. You’d need to use a load balancer if there is L3 separation.
  • 6.  RE: publisher virtual IP on different subnet with physical IP
    Posted Mar 12, 2018 02:49 PM
    The two common use cases for the VIP are:
    - Captive Portal redundancy (You point the DNS entry to the VIP and in case
    one of the nodes fails your CP will still be available)
    - TACACs/RADIUS for switches that don't support two entries for
    TACACs/RADIUS servers or dont have a mechanism to determine if the
    TACACs/RADIUS server is unavailable (This is not very common)
