Pull Endpoints through API
  • 1.  Pull Endpoints through API
    Posted Mar 27, 2018 04:31 AM
    Hi community,
    I need to pull a list of all end-points (including details like device type, hostname, ip, etc.) from ClearPass through its API. The process that works is:
    First, pull a high-level list of all available MAC addresses: /api/endpoint
    Then iterate that list and run two API calls per MAC:
     - /insight/endpoint/mac/001aef1a188b
     - /async_netd/deviceprofiler/endpoints/001aef1a188b
    I need to run the call to async_netd in order to get the hostname per device as the /insight/endpoint/mac API wouldn't return that info.
    My question is: is there a more efficient way to pull all those end-point details?
    The reason this is not very efficient: let's assume you have an environment with 10.000 end-points. I will need to run 1 + 10.000 + 10.000 API calls to get all details from all end-points. That takes more than 20 minutes to process and puts the ClearPass server under quite some load for quite a long time.
    Any ideas on improving this?
    Kurt
  • 2.  RE: Pull Endpoints through API
    Posted Mar 27, 2018 09:26 AM
    What is the goal of pulling all of the endpoints?
  • 3.  RE: Pull Endpoints through API
    Posted Mar 27, 2018 09:57 AM
    Synchronizing them with a CMDB
  • 4.  RE: Pull Endpoints through API
    Posted Aug 05, 2018 12:00 PM
    I have to perform the same action. Do you have a more efficient solution?
  • 5.  RE: Pull Endpoints through API
    Posted Aug 06, 2018 04:40 AM
    No, I did not find a more efficient solution :(
  • 6.  RE: Pull Endpoints through API
    Posted Oct 29, 2019 06:42 AM
    curl -u '***':'***' https://ldn1nacv.ebrd.com/insight/endpoint/mac/4cbc4882460e
    is that format is correct to pull endpoint
    can you help me out because format gives me error
  • 7.  RE: Pull Endpoints through API
    Posted Oct 29, 2019 09:04 AM
    Let me try to help, but to make it easier, post the exact line that you use
    plus the exact output that you get. (you can write username/password
    instead of the actual values but keep the quotation marks or apostrophes or
    whatever you use).
    ______________________________
    *Or Pinchasof** | *Security Researcher
    *orp@medigate.io* | *+972-52-363-8420* | *www.medigate.io
    Yigal Alon 94 st., Tel-Aviv, Israel
